HackerBot XY system
Revision as of 06:58, 22 October 2015 by Balestrino (talk | contribs) (Step 20: XY Shafts)
HackerBot Documentation
Support plates
Support plates drawings
qty part name description/notes
1 Front right support plate File:Support plate 50x50 L.80mm Front-Right.PDF
1 Front left support plate File:Support plate 50x50 L.80mm Front-Left.PDF
1 Back right support plate File:Support plate 50x50 L.140mm Back-Right.PDF
1 Back left support plate File:Support plate 50x50 L.140mm Back-Left.PDF
Back Right support plate
6 M6x12 Hex screw
6 M6 T-Nut Misumi HNTF6-6 or Bosch 3842501753
Back Left support plate
1 Back Left support plate
6 M6x12 Hex screw
Front Right support plate
1 Back Right support plate
4 M6x12 Hex screw
4 M6 T-Nut Misumi HNTF6-6 or Bosch 3842501753
Front Left support plate
1 Front Left support plate
4 M6x12 Hex screw
Support plate assembly
Cubic Slider
Cubic Slider
4 Cubic slider
8 Cubic slider belt clamp File:Belt clamp.stl print 100% infill
16 M3x12 screw kit
4 Cubic slider bushing
Assemble the cubing slider:
XY Shafts
XY Shafts
2 Shaft 8mm. length 465mm
2 Shaft 8mm. length 438mm
8 GT2 20 tooth pulley (8mm bore)
8 XY Shim File:XY Shim.pdf
8 608ZZ Bearings outer diameter: 22mm, inner: 8mm, thickness: 7mm
8 Bearing housing Aluminum or 3D printed: File:Bearing Housing.stl
32 M3x16 screw kit fixes the bearing supports with the plates
Using the cubic sliders assemble the shafts as in photo:
HackerBot step 20
HackerBot step 20.1
double check:
  • the correct orientation of Cubic sliders
  • shafts should not be touching the Supports plate
  • Cubic sliders should be running well on the shafts, and shafts should turn easily
DON'T tighten the screws.
Step 21: XY Belts
XY Belts
4 GT2 open belt length 830mm XY core belts
Place the four belts like as show below:
HackerBot step 21
DON'T pull the belts.
Step 22: XY Motors
XY Motors
2 Stepper motor Nema 17 2.5A (or 1.7A), shaft 5mm
2 GT2 20 teeth pulley 5mm bore
2 GT2 20 teeth pulley 8mm bore
8 M3x12 screw kit
1 GT2 closed belt 77 teeth SDP-SI.COM (6R51M077060)
1 GT2 closed belt 66 teeth SDP-SI.COM (6R51M066060)
Y Motor (right side)
Use a GT2 closed belt 66 teeth:
HackerBot step 22
X Motor (backside)
Use a GT2 closed belt 77 teeth:
HackerBot step 22.1
Step 23: XY Motor belt tighteners
Belt Tightner
1 Belt Tightener File:Belt tightener.PDF
1 Belt Tightener short File:Belt tightener small.PDF
2 624zz bearing
2 M3x15 screw with 2 M3 nuts
2 M3x20 screw with 2 M3 nuts
6 M3 washer
HackerBot step 23
HackerBot step 23.1
HackerBot step 23.2
Step 24: Head assembly
Head
2 Shaft 8mm length 370mm Head shaft
1 Head v2 File:Head Bowden dual.stl File:Head Bowden dual FAN DUCT.stl
4 Linear Bearing LM8UU
1 Pneumatic fittings
4 M3x8 grub screw fixes the hotends
Insert the four linear bearings in the head, fasten the pneufit and the grub screws (remember to thread the 3d-printed head holes):
HackerBot step 24
Insert shafts in the head
HackerBot step 24.1
Place the head assembly AND take care to not force anything when mounting it:
HackerBot step 24.2
TIPS:
  • for easy mounting put the cubic sliders on a side
** XY COMPLETE **
** GO TO >> HackerBot Z system **
