HackerBot XY system
Revision as of 07:01, 22 October 2015 by Balestrino (talk | contribs)
HackerBot Documentation
Support plates
qty | part name | description/notes |
1 | Front right support plate | File:Support plate 50x50 L.80mm Front-Right.PDF |
1 | Front left support plate | File:Support plate 50x50 L.80mm Front-Left.PDF |
1 | Back right support plate | File:Support plate 50x50 L.140mm Back-Right.PDF |
1 | Back left support plate | File:Support plate 50x50 L.140mm Back-Left.PDF |
1 | Back right support plate | |
6 | M6x12 Hex screw | |
6 | M6 T-Nut | Misumi HNTF6-6 or Bosch 3842501753 |
1 | Back Left support plate | |
1 | Back Right support plate | |
4 | M6x12 Hex screw | |
4 | M6 T-Nut | Misumi HNTF6-6 or Bosch 3842501753 |
1 | Front Left support plate | |
Support plate assembly
Cubic Slider
4 | Cubic slider | |
8 | Cubic slider belt clamp | File:Belt clamp.stl print 100% infill |
16 | M3x12 screw kit | |
4 | Cubic slider bushing |
Assemble the cubing slider:
XY Shafts
2 | Shaft 8mm. length 465mm | |
2 | Shaft 8mm. length 438mm | |
8 | GT2 20 tooth pulley (8mm bore) | |
8 | XY Shim | File:XY Shim.pdf |
8 | 608ZZ Bearings | outer diameter: 22mm, inner: 8mm, thickness: 7mm |
8 | Bearing housing | Aluminum or 3D printed: File:Bearing Housing.stl |
32 | M3x16 screw kit | fixes the bearing supports with the plates |
Using the cubic sliders assemble the shafts as in photo:
double check:
- the correct orientation of Cubic sliders
- shafts should not be touching the Supports plate
- Cubic sliders should be running well on the shafts, and shafts should turn easily
DON'T tighten the screws.
XY Assembly
4 | GT2 open belt length 830mm | XY core belts |
Assembly the XY system with four belts like as show below:
DON'T tighten the belts.
XY Motors
2 | Stepper motor Nema 17 | 2.5A shaft 5mm |
2 | GT2 20 teeth pulley | 5mm bore |
2 | GT2 20 teeth pulley | 8mm bore |
8 | M3x12 screw kit | |
1 | GT2 closed belt 77 teeth | |
1 | GT2 closed belt 66 teeth |
Y Motor (right side)
Use a GT2 closed belt 66 teeth:
X Motor (backside)
Use a GT2 closed belt 77 teeth:
Step 23: XY Motor belt tighteners
1 | Belt Tightener | File:Belt tightener.PDF |
1 | Belt Tightener short | File:Belt tightener small.PDF |
2 | 624zz bearing | |
2 | M3x15 screw | with 2 M3 nuts |
2 | M3x20 screw | with 2 M3 nuts |
6 | M3 washer |
Step 24: Head assembly
2 | Shaft 8mm length 370mm | Head shaft |
1 | Head v2 | File:Head Bowden dual.stl File:Head Bowden dual FAN DUCT.stl |
4 | Linear Bearing | LM8UU |
1 | Pneumatic fittings | |
4 | M3x8 grub screw | fixes the hotends |
Insert the four linear bearings in the head, fasten the pneufit and the grub screws (remember to thread the 3d-printed head holes):
Insert shafts in the head
Place the head assembly AND take care to not force anything when mounting it:
TIPS:
- for easy mounting put the cubic sliders on a side
** XY COMPLETE **
** GO TO >> HackerBot Z system **
