HackerBot structure
Base structure
Hackerbot 2.0 uses MISUMI profile, but you can also use Bosch-Rexroth
qty | part name | description/notes | |
11 | EFSFB6-3030-450 | 3slot aluminum extrusion 450mm | |
4 | EFSTB6-3030-600 | 2slot aluminum extrusion 600mm | |
4 | EFSB6-3030-450 | 30mm aluminum extrusion 450mm | |
36 | HBLFSB6-C-SET | Bracket set (pre assembly) | |
2 | HBLBS6 | Internal bracket 8mm slot | |
2 | FBF33-8-30 | rubber foot | |
4 | HBLFSB6-C-SEP | Bracket set (post-assembly) | |
4 | HFCB6-3030-B | Set plugs profile |
Z motor mount
1 | Aluminum profile 30x30 450mm | |
4 | Plexy support | |
1 | Z stepper plate | File:Z-stepper plate.PDF |
2 | M6 T-head bolt | Bosch 3842523921 |
2 | T-nut | Bosch 3842523925 |
Mount the Z stepper plate in the mid of the profile:
Using two M6 T-head bolts and two T-Nuts.
TIP: measure 185mm from the edge of the profile.
Place two internal brackets at the end of the profile:
Place the profile in the structure with a distance of 46 mm from the base profile ( between the internal sides):
Fix it and leave a gap of 85 mm between this profile and the lower one:
Step 9: left middle profile
5 | Plexy support | |
2 | Internal bracket | Bosch 3842535577 |
Take the profile for the left middle side and insert two plexy supports and two internal brackets:
Step 10: Upper Z backside profile
7 | Plexy support |
Place one plexiglass support in each backside columun:
In the Upper Z profile put three supports upside and two downside.
Put the internal brackets at the end of the profile:
Fix it with a distance equal to 342 mm between the internal vertical surfaces of z-upper profile and mid profile on the rear side:
Step 11: Backside Top profile
2 | M3 square nut |
Take two supports and insert a M3 square nut.
Insert one support in the left side (see photo) and another one in the right side:
Put three plexy supports and two internal brackets in the aluminum profile :
Mount the profile in the backside:
Step 12: Top Right profile
6 | Plexy support |
Per side insert two plexy supports in the vertical strut. Total four supports
Put two plexy supports in the aluminum profile and two internal brackets:
Mount the profile in position:
Step 13: Top Left profile
6 | Plexy support |
Do the same as step 12 but for left side.
Step 14: Top Front profile
Put two internal brackets:
