HackerBot structure
HackerBot Documentation
Base structure
- Hackerbot 2.0 uses MISUMI profile, but you can also use Bosch-Rexroth
- 600mm profile should be M8 threaded one side (length of thread about 40mm)
- Assemble the frame structure checking the squareness and assemble it also on a flat workbench
- Insert first the pre assembly nut into the slots
- Last step is the n.4 Brackets post assembly (check the photo)
qty | part name | description/notes |
11 | EFSFB6-3030-450 | 3slot aluminum extrusion 450mm |
4 | EFSTB6-3030-600 | 2slot aluminum extrusion 600mm |
4 | EFSB6-3030-450 | 30mm aluminum extrusion 450mm |
36 | HBLFSB6-C-SET | Bracket set (pre assembly) |
2 | HBLBS6 | Internal bracket 8mm slot |
4 | FBF33-8-30 | M8 rubber foot |
4 | HBLFSB6-C-SEP | Bracket set (post-assembly) |
4 | HFCB6-3030-B | Set plugs profile |
Z motor mount
1 | Aluminum profile 30x30 450mm | |
4 | Plexy support | |
1 | Z stepper plate | File:Z-stepper plate.PDF |
2 | M6 T-head bolt | Bosch 3842523921 |
2 | T-nut | Bosch 3842523925 |
Mount the Z stepper plate in the mid of the profile:
Using two M6 T-head bolts and two T-Nuts.
TIP: measure 185mm from the edge of the profile.
Place two internal brackets at the end of the profile:
Place the profile in the structure with a distance of 46 mm from the base profile ( between the internal sides):
Fix it and leave a gap of 85 mm between this profile and the lower one:
** STRUCTURE COMPLETE **
** GO TO: HackerBot XY system **
