HackerBot structure
Revision as of 04:58, 22 October 2015 by Balestrino (talk | contribs) (Base structure)
HackerBot Documentation
Base structure
  • Hackerbot 2.0 uses MISUMI profile, but you can also use Bosch-Rexroth
  • 600mm profile should be M8 threaded one side (length of thread about 40mm)
  • Assemble the frame structure checking the squareness and assemble it also on a flat workbench
  • Insert first the pre assembly nut into the slots
  • Last step is the n.4 Brackets post assembly (red one brackets, check the photo)
Structure BOM
qty part name description/notes
11 EFSFB6-3030-450 3slot aluminum extrusion 450mm
4 EFSTB6-3030-600 2slot aluminum extrusion 600mm
4 EFSB6-3030-450 30mm aluminum extrusion 450mm
36 HBLFSB6-C-SET Bracket set (pre assembly)
2 HBLBS6 Internal bracket 8mm slot
4 FBF33-8-30 M8 rubber foot
4 HBLFSB6-C-SEP Bracket set (post-assembly)
4 HFCB6-3030-B Set plugs profile
Structure assembly
Z motor mount
Mid plane
1 Aluminum profile 30x30 450mm
4 Plexy support
1 Z stepper plate File:Z-stepper plate.PDF
2 M6 T-head bolt Bosch 3842523921
2 T-nut Bosch 3842523925
Mount the Z stepper plate in the mid of the profile:
Using two M6 T-head bolts and two T-Nuts.
TIP: measure 185mm from the edge of the profile.
Place two internal brackets at the end of the profile:
HackerBot step 6.3
Place the profile in the structure with a distance of 46 mm from the base profile ( between the internal sides):
HackerBot step 6.4
Fix it and leave a gap of 85 mm between this profile and the lower one:
HackerBot step 8.2
** STRUCTURE COMPLETE **
** GO TO: HackerBot XY system **
