Portabee
Release status: Working
Description | Printrbot variant that could be packed in a laptop bag
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | Printrbot variations
CAD Models | hhmmm...
External Link |
The portabee, is a Printrbot / Wallace variant which was designed to be able to be packed into a laptop bag. It has a 3mm FR4 matte black heated longbed, default gen6.d electronics which allows direct SD card printing, use of heated longbed as well as a channel for a micro fan. The build area is 120mm x 120mm x 120mm.
- 1 Specifications
- 2 Building Documentation
- 3 Where To Purchase
- 4 Where To Get Source Files
- 5 Updated information for 2021
Specifications
- Printed Parts: ???
- Non-Printed Parts: ???
- Printing Size: 12cm x 12cm x 12cm (apprx. 4.75"x4.75"x4.75")
- Material Costs: ???
- Precision: ??? (position), ??? (printing)
- Speed: ??? (position), ??? (printing)
as looked up at RomScraj.com (if documentation links are outdated, look up again new links).
Where To Purchase
- http://romscraj.com - USD 490 unassembled, USD 640 assembled
- http://portabee3dprinter.com - USD 499 unassembled, USD 699 assembled
This somewhat older printer unfortunately seems no longer to be available, making it hard to find relevant information. This section will summarise relevant information that is still available on the web as of 2021.
Latest corporate homepage from 2018
https://web.archive.org/web/20181031151948/http://portabee3dprinter.com/
Official setup page
https://web.archive.org/web/20180919005414/http://portabee3dprinter.com/support/portabee-kit-docs/
This page includes:
- Assembly manual
- First print using Pronterface and Cura software
- STL files for printer parts
- Upgrades for the printer such as:
- Y-axis brace
- Filament guide
- Fan frame
Firmware
https://web.archive.org/20160604072127/http://portabee3dprinter.com:80/portabee-firmware-guide/
slic3r settings
The following settings come from the file config_300_portabee_2.ini at github.com/Lunavast/Portabee/downloads/ . Save this file and then import it into slic3r via File->Load Config.
In particular, pay attention to the below settings concerning maximum print speed for the Portabee (nothing above 40 mm/s) and the retraction settings.
acceleration = 0 bed_size = 120,120 bed_temperature = 0 bridge_fan_speed = 100 bridge_flow_ratio = 1 bridge_speed = 40 brim_width = 0 complete_objects = 0 cooling = 0 disable_fan_first_layers = 1 duplicate = 1 duplicate_distance = 6 duplicate_grid = 1,1 end_gcode = M104 S0 ; turn off temperature\nM1140 S0\nG28 X0 ; home X axis\nM84 ; disable motors extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_axis = E extrusion_multiplier = 1 extrusion_width = 0 fan_always_on = 0 fan_below_layer_time = 60 filament_diameter = 3.0 fill_angle = 45 fill_density = 0.2 fill_pattern = rectilinear first_layer_bed_temperature = 0 first_layer_extrusion_width = 0 first_layer_height = 100% first_layer_speed = 36% first_layer_temperature = 0 g0 = 0 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 50 infill_every_layers = 1 infill_extrusion_width = 0 infill_speed = 40 layer_gcode = layer_height = 0.36 max_fan_speed = 100 min_fan_speed = 35 min_print_speed = 10 notes = nozzle_diameter = 0.5 output_filename_format = [input_filename_base].gcode perimeter_acceleration = 25 perimeter_speed = 36 perimeters = 2 perimeters_extrusion_width = 0 post_process = print_center = 60,60 randomize_start = 1 retract_before_travel = 2 retract_length = 1 retract_lift = 0 retract_restart_extra = 0 retract_speed = 10 rotate = 0 scale = 1 skirt_distance = 3 skirt_height = 1 skirts = 1 slowdown_below_layer_time = 15 small_perimeter_speed = 36 solid_fill_pattern = rectilinear solid_infill_speed = 40 solid_layers = 3 start_gcode = G28 ; home all axes support_material = 0 support_material_angle = 0 support_material_pattern = rectilinear support_material_spacing = 2.5 support_material_threshold = 45 support_material_tool = 0 temperature = 0 threads = 2 top_solid_infill_speed = 38 travel_speed = 128 use_relative_e_distances = 0 z_offset = 0
Detailed review and usage guide
Includes images of sample prints from the Portabee, troubleshooting guide, and tips about what to expect.
http://www.cygig.com/2013/08/review-portabee-3d-printer-most.html
Alternate URL: https://forums.vrzone.com/chit-chatting/2904838-review-portabee-3d-printer-the-most-afforable-singapore.html
Portabee print troubleshooting guide
https://i.imgur.com/iSEdqeM.jpg
Initial configuration
Hardware
Insert filament
- Fully loosen the 4 nuts on idler block until the nuts are at the end of their respective screws, but do not remove the nuts from the screws. This step is easier if you replace the original hex nuts (which must be adjusted with a tool) with finger-adjustable knurled nuts (https://en.wikipedia.org/wiki/Knurled_nut).
- Pull idler block away from the extruder so that there is a clear path from the filament feed hole at the top of the extruder, all the way down to the hot end. The path for the filament should not be obstructed by the extruder bearing (because the idler block has been pulled away from the extruder so as not to block the filament feed path).
- Heat the hot end to the desired extrusion temperature (180 degrees for PLA).
- Push the filament all the way through the extruder hole, all the way down until it reaches the end of the hot end. The filament should be unobstructed by the extruder's internal bearing. As you push down on the filament, it should melt and ooze out of the hot end.
- Tighten the 4 nuts on the idler block, so that the extruder's bearing now grips the filament (by pressing it against the extruder's internal toothed brass gear).
- Clean the tip of the hot end.
Remove filament
- Pull idler block away from the extruder, so that the extruder no longer grips the filament.
- Set the hot end to 90 degrees (for PLA) and wait for the temperature to stabilize.
- After the temperature stabilizes, pull the filament out vertically from the filament feed hole.
Firmware
Calibrate E-steps
Updating the firmware
- warning: multiple board variants
Software
- Limit speed to less than 40 mm/second, or else print quality may suffer.
- Reference 1: Initial slow speed for test prints is recommended as 30 mm/second. https://web.archive.org/web/20180919005414/http://portabee3dprinter.com/support/portabee-kit-docs/
- Reference 2: slic3r configuration file at https://github.com/downloads/Lunavast/Portabee/config_300_portabee_2.ini limits maximum print speed to 40 mm/second.
- Reference 3: Portabee review at https://github.com/downloads/Lunavast/Portabee/config_300_portabee_2.ini states that print quality suffers above 40 mm/second.
Printing tips
Before moving the printer
- Confirm all screws and belts are tightened appropriately. Items prone to come loose due to vibration in normal use are:
- The set screw on the plastic drive gear on the extruder motor shaft
- The set screws on the Z leadscrews
- The screws holding the smooth Z rods in place
- The nuts securing the Y-axis support rods to the plastic base
- The screws holding the motors (X, Y, and Z) in place
When moving the printer
- Confirm all screws and belts are tight.
- Use two hands, one to grasp each z stepper motor. Be careful not to twist the assembly.
- It is inadvisable to grasp the Z rods (either the Z leadscrews, or the smooth Z rods), because this may cause them to become loose and/or misaligned.
Before turning on the printer
- Prepare an emergency-stop switch to cut the power to the printer immediately (or be prepared to yank the power cord if needed).
- Confirm the end stop switches are physically mounted so that they will activate when the print head reaches the start of each axis. If the switches are wrongly mounted so they do not activate, then the motors may try to drive the print head past the physical dimensions, causing a crash into and physical damage of plastic parts securing the X, Y, and/or Z axes.
After turning on the printer
- Turn on the extruder barrel fan with M106. It should always be on.
- Adjust the Z endstop so the nozzle is an appropriate distance from the print bed.
- Using Pronterface software, move the print head to the home position on the X, Y, and Z axes. Be prepared to cut power instantly (via the emergency-stop power switch) if the print head crashes into the printer sides or the print bed.
- Level the print bed.
- Calibrate the E-steps.
- Recommended starting value is 514 (reference: https://web.archive.org/web/20180919005414/http://portabee3dprinter.com/support/portabee-kit-docs/).
- Should be possible to set via M92 command (reference: https://marlinfw.org/docs/gcode/M092.html).
Before starting the print
- Ensure the print dimensions do not exceed the print bed size (12cm x 12cm x 12cm), or else the motors may try to drive the print head past the physical dimensions, causing a crash into and physical damage the X, Y, and/or Z axes and/or the print bed.
- Ensure filament flows freely
- Manually heat the hot end to desired temperature
- Manually set Z to 4 cm above the print bed, and repeatedly extrude filament until it flows smoothly.
- After the filament flows smoothly, immediately (within a few seconds):
- Clean the excess filament from the print bed
- Clean the nozzle of excess filament (e.g. wipe it quickly with a thick paper towel, taking care not to get burned by the hot end!)
- Start the print. If you wait too long (a minute or more) after the smooth filament flow begins, then the flow may again become poor, requiring re-extrusion to get the filament flowing freely again.
During the print
- Confirm the extruder barrel fan is always on.
- If the fan stops when the print starts:
- Abort the print -- in Pronterface, press "Pause", then "Reset printer".
- Turn on the fan with M106.
- In slic3r, check the option to turn the fan always on.
- Re-slice the 3D model, re-import into Pronterface, and try printing again. This time, the fan should be on.
