Prusa i3 Rework Bill of materials
Revision as of 08:57, 6 August 2013 by EMotion-Tech (talk | contribs) (Created page with '{{Languages|Prusa_i3_Rework}} {{Prusa_i3_Rework_Sommaire_EN}} __FORCETOC__ = Printed parts = [[Image: Prusa-i3-Nomenclature-pieces-plastiques.jpg|thumb|600px|center|Printed par…')
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Printed parts
Printed parts needed to build the Prusa i3 Rework.
Extruder
Parts needed to build the Prusa i3 Rework.
Smooth and threaded rods
  • 2x Smooth rod Ø8x320 mm
  • 2x Smooth rod Ø8x350 mm
  • 2x Smooth rod Ø8x370 mm
  • 2x Threaded rod M5x300 mm
  • 4x Threaded rod M10x210 mm
  • 2x Threaded rod M10x380 mm
Mechanical parts
Mechanical parts needed to build the Prusa i3 Rework.
Heated bed
Parts needed to build the heated bed of Prusa i3 Rework.
Electronics
Electronics needed to build the Prusa i3 Rework.
Screws, nuts and washers
Screws, nuts and washers needed to build the Prusa i3 Rework.
Aluminium frame
  • 1x Single frame
  • 1x Heated bed mount
