Mendel mechanical construction
Mendel Build Documentation
Index | Installing RepRap on your computer | "Official" Electronics | CAM Toolchains | Microcontroller firmware installation | Mechanical construction | Electronic wiring | Commissioning | Mechanical Drawings
Mechanical: Overview | Mendel solid model files | Procurement | Preparation of materials | Assembly notes | Extruder | X-axis | Z-axis | Y-axis | Circuit boards | Frame | Squaring the axes
These pages will show you how to build the mechanical structure of RepRap Version II "Mendel". Check out the overview to get a fast introduction to Mendel's design. The Mendel assembly data sheet has been designed to provide all the procurement and assembly data you need, and can be relied upon if you prefer not to follow instructions. However, it's recommended that you do assembly in the order of the list below.
- Overview
- Mendel solid model files
- Procurement
- Preparation of materials
- Assembly notes
- Extruder
- X-axis
- Z-axis
- Y-axis
- Circuit board attachment
- Frame
- Squaring the axes
See Also: LaserCut Mendel Assembly
