Re: Large-scale 3d printer November 12, 2015 12:02PM |
etfrench
Are you sure? I was under the impression that ABS worked the same as acrylic where glued joints are just as structurally sound as the rest of the material.
Re: Large-scale 3d printer November 12, 2015 01:37PM |
davew_tx
Val,
For your big glass idea, be prepared for non flat conditions all over the surface. Pulling the edges down will only work locally near those points, but the center of the glass will not respond to any edge manipulations.
The cork in the center will not care that you tweaked some edge. it has no reason to compress even if you moved an edge 1" or more.
To solve that, you could use rear view mirror glue and put an array of bolts across the under surface. File the bolt head flat first and glue to the glass. I've had this idea hold together for a couple of years now.
Then, using double nuts or springs and wingnuts on brackets you could push up or pull down specific areas on within the large area.
It's a solution, and there are other ways to solve the issue, but know that the flatness will not be achieved without specific design solutions in multiple places.
The large Stratasys 900 does it that way (patent 8153183) and you have a similar size bed.
I've been inside one of those, and they have a precision ground 15mm thick stainless (?) sheet and they can't keep it flat without this multi-point mounting method.
In my experience, the electronics, like the board and the motors would survive in chambers at 70C or more. given the small size of most control boards, those are easy to mount outside, but the motors can handle it.
I'd guess you could run motors up to 80-90C before the lacquer on the windings smokes.
Stratasys has misc pcbs inside on many of their machines, but they have the logic outside.
The expensive machines that run high enclosure temperatures for printing the Ultem material have the motors outside the enclosure.
They put LED boards, switch boards, encoder readers, and thermocouple reader boards on the inside of UPrints and Dimension machines. The logic and control is outside.
They do bring fresh air into the print head and dump it on a few places, which might create a cooling cloud/shroud near some of the boards.
Re: Large-scale 3d printer November 12, 2015 09:43PM |
Re: Large-scale 3d printer November 20, 2015 01:45AM |
bonmotwang
Hi Val
If you find a online deflection calculator, you will understand what Dave is talking about.
The thickness and the self weight are racing each other. You will be surprised about the thickness required in your design to achieve the flatness.
Multiple point adjustable support is the right direction and I am designing that in my printer too. my glass is 880mmx580mm. I am planning to have 6 points.
My goal is not to be absolute flat. I will use those 6 points to adjust the surface to follow the extruder XY plane, which isn't absolute flat either. as long as these two surfaces match, I am happy.
Re: Large-scale 3d printer November 20, 2015 09:27AM |
Re: Large-scale 3d printer November 20, 2015 11:02AM |
bonmotwang
Hi Val
I like your machine. very solid, which is my way into this.
I just kicked off CNC machining last night. There are 26 different kind of alum. parts.
But I have been debating with myself at late stage of corexy design of my machine: Do I really need corexy or just use normally way.
My frame is about 1000mmx880mm and 900mm height.
Total weight of the machine may hit 50Kg.
I put my work order on hold now, and give myself a couple more days to decide. Right now I am thinking about abandon corexy and go back to normal way because the motor weight isn't an issue in this type of big frames.
Re: Large-scale 3d printer November 20, 2015 11:16AM |
Re: Large-scale 3d printer November 20, 2015 11:25AM |
bonmotwang
Great recommendation Val.
You are right, and I should get it kicked off. and see what we get. A lot of work has been poured into design the whole assembly. Changing direction at this time is no fun.
Thanks Val.
Again, nice chat :-)
Re: Large-scale 3d printer November 23, 2015 12:04AM |
Re: Large-scale 3d printer November 24, 2015 04:08PM |
bonmotwang
If I decided to enclose the chamber, motors are outside.
But first step is just PLA.
Re: Large-scale 3d printer November 24, 2015 05:41PM |
Re: Large-scale 3d printer November 24, 2015 10:55PM |
Re: Large-scale 3d printer November 24, 2015 10:56PM |
bonmotwang
My machine was designed to print ABS.
But I decided to learn how thermal stress is going to affect my machine first. So mechanically, only minimal moving parts will be in the chamber if walls would be added.
Re: Large-scale 3d printer November 25, 2015 03:16AM |
Re: Large-scale 3d printer November 25, 2015 04:30PM |
papabur
The sE1X is very customizable in which, with just some longer 2020 extrusions/smooth rods/threaded rods you could easily get 20" out of one..just a thought. The original design is 11.8"x11.8"x10" and is available as a kit at [mobious.org] . Also has dual extrusion available now. If you'd like to discuss more about making a larger sE1X, let me know!
Re: Large-scale 3d printer December 18, 2015 05:49PM |
Re: Large-scale 3d printer December 20, 2015 03:33AM |
Re: Large-scale 3d printer December 20, 2015 02:49PM |
Re: Large-scale 3d printer December 20, 2015 07:25PM |
Re: Large-scale 3d printer December 20, 2015 10:17PM |
JuliaV
To make something that big in ABS would require a heated chamber at about 70C.
Re: Large-scale 3d printer December 24, 2015 12:21PM |
Re: Large-scale 3d printer January 14, 2016 12:38PM |
Re: Large-scale 3d printer January 19, 2016 12:24PM |
davew_tx
Any updates on the beast?
Re: Large-scale 3d printer January 19, 2016 12:47PM |
davew_tx
Re: Large-scale 3d printer January 21, 2016 04:20AM |
Re: Large-scale 3d printer January 21, 2016 05:48AM |
Re: Large-scale 3d printer January 21, 2016 04:52PM |
Re: Large-scale 3d printer January 21, 2016 06:37PM |
Re: Large-scale 3d printer January 21, 2016 06:52PM |
Admin Registered: 16 years ago Posts: 13,906 |
Re: Large-scale 3d printer January 28, 2016 06:33AM |
Yes large printers exists butQuote
VDX
... there are several cartesian- and delta-based frames with up to 12 meter building height for 3D-printing architectural parts nad complete houses out from concrete.
In future this will get common and even bigger - especially in Japan and China they're fond of "printed houses" ... and NASA too has plans to install 3D-printers on the moon or on Mars to 'print' habitates ...
