Re: Large-scale 3d printer May 15, 2016 02:36PM |
epicepee
Excellent!
One minor trick that has helped my bed heat faster is covering the unused portions with aluminum foil, kapton-taped down. It reflects the heat that might otherwise radiate away. It won't help if you're using the whole bed, of course, but if you're only using a bit it can make a huge difference in terms of heating speed and power required to hold temperature.
Re: Large-scale 3d printer May 28, 2016 10:17PM |
Re: Large-scale 3d printer May 30, 2016 02:53AM |
Re: Large-scale 3d printer May 30, 2016 07:10AM |
Re: Large-scale 3d printer May 30, 2016 11:52AM |
JamesK
It lives! Congratulations. Those are the most under-stated postings imaginable for bringing this beast to life
Those look like tiny layers for a printer that size. Getting a huge printer to print small parts as accurately as a small printer is always going to be a stretch. Fling a 1mm nozzle on there, print something a meter long and make us all jealous!
Re: Large-scale 3d printer May 31, 2016 01:45PM |
Re: Large-scale 3d printer June 04, 2016 01:52AM |
Re: Large-scale 3d printer June 04, 2016 02:44AM |
I believe you are talking about 3dp printers.Quote
Lymphomaniac1
I saw a commercial one on television recently large enough to make a chair. It took over a week to make the chair.
Re: Large-scale 3d printer June 04, 2016 09:42PM |
Re: Large-scale 3d printer June 05, 2016 05:02AM |
Re: Large-scale 3d printer June 05, 2016 11:19AM |
the_digital_dentist
How's the foam bed working for you? I can't be sure from the pix- are you printing on a raft?
Re: Large-scale 3d printer June 05, 2016 12:12PM |
Re: Large-scale 3d printer June 05, 2016 12:31PM |
the_digital_dentist
I found that the foam is a little springy, and so corners of parts printed directly on the foam (without a brim) tended to lift a bit. Using a raft fixed that- the corners of the raft would lift a little but the print was fine. Also, when printing the part directly on the foam a little of the foam remains embedded in the bottom surface of the print. Not a problem most of the time, but maybe once in a while.
You can sand the surface with a piece of coarse sandpaper to smooth it if it starts getting to uneven.
Re: Large-scale 3d printer June 05, 2016 12:32PM |
Re: Large-scale 3d printer June 05, 2016 01:48PM |
val c.
wanted to ask you, how did you get the idea to use foam?
Re: Large-scale 3d printer June 05, 2016 10:56PM |
the_digital_dentist
val c.
I was having trouble getting prints to stick to my printer's glass bed at the time and started thinking about how to fix that. I saw a 90's vintage Stratasys FDM1600 industrial printer at the makerspace that prints on urethane foam (that they sell for a ridiculous price). I tried a piece of the Stratasys foam and it worked well, so I started looking for a substitute that was available cheaply. I figured it had to be something that wouldn't decompose at nozzle temperatures, which quickly led to PIR. Then I checked availability of PIR, found it for sale at Home Depot, and also found a sheet of it in the woodshop at the makerspace so I cut it up and tested it. When I tested it I used carpet tape to hold piece on my glass bed and used the z offset in slic3r to move the first layer up. It was the first material I tried and it worked well. The rest, as they say, is history. The guy who owns the Stratasys printer at the makerspace (haveblue) now uses PIR.
I ultimately went with a heated tooling plate bed for my printer even though it's more trouble to set up, because it has less on-going maintenance to do. For a large printer like yours, where a bed heater would cost a fortune to install and operate, the foam is perfect. There's no messing with different glues and potions because everything sticks to it. There's no waiting for a giant bed to heat up. There's no need to get a perfectly flat and level surface, both big problems for big printers.
If I were making a large printer I'd probably design the frame that holds the foam so it can hold different sized pieces of foam, and then use foam that is sized to match the print. That way you don't end up using big pieces of foam for small parts. Of course, you can always print off-center on the bed and move the prints around on a large piece of foam. Either approach should help minimize foam cost.
Re: Large-scale 3d printer June 06, 2016 12:50AM |
Re: Large-scale 3d printer June 06, 2016 01:19AM |
Re: Large-scale 3d printer June 06, 2016 04:10PM |
Re: Large-scale 3d printer June 06, 2016 04:40PM |
StupendousMan
I promised to build a largeish (has to fit through doors) printer for a startup. I have neither talent nor time to roll my own, so help me make a choice here, please. I'm open to anything with a decent BOM, these are just what I've stumbled into.
Cbot / Dbot. Proven design, but is it still rigid enough after scaling the size up significantly and hanging double direct extruders on?
Open Gigabot, this is the right size with no changes. Brand new and unproven. Does anyone know more about this?
Traditional cartesian? For example Voxel Ox looks sturdy enough to scale up a lot. Slow?
It will be using two volcanoes with direct extruders (maybe titans), a duet board, 24v, PIR bed (thank you DD!), and printing PLA (for starters).
Re: Large-scale 3d printer June 17, 2016 11:06AM |
Re: Large-scale 3d printer June 17, 2016 11:12AM |
Re: Large-scale 3d printer June 17, 2016 11:20AM |
Re: Large-scale 3d printer June 17, 2016 11:23AM |
Re: Large-scale 3d printer June 17, 2016 11:29AM |
Re: Large-scale 3d printer June 17, 2016 11:32AM |
Re: Large-scale 3d printer June 17, 2016 11:34AM |
Re: Large-scale 3d printer June 17, 2016 11:35AM |
Re: Large-scale 3d printer June 17, 2016 11:39AM |
JamesK
Electric Yoda head? That might empty the park
Re: Large-scale 3d printer June 17, 2016 03:37PM |
