Rack and Pinion for X-Axis
Posted by theodleif
April 25, 2012 02:11PM
Based on [www.thingiverse.com] I built a replacement for the belt on the x-axis of my Prusa. As Triffid Hunter suggested in his comment, I used a small pinion instead of the big one.
The result looks like this:
Today I tested it:
I observed no backlash. Next I will replace the y-belt.
Re: Rack and Pinion for X-Axis
April 25, 2012 02:47PM
Very nice! I imagine that it probably lowers your maximum speed and acceleration, does it not
Cameron
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
April 25, 2012 03:10PM
48 mm/s were no problem.
Even 64 mm/s works accurately:
Edited 1 time(s). Last edit at 04/25/2012 03:36PM by theodleif.
April 26, 2012 07:31PM
could a person try switching it to, m4 threaded rod to save on mass or is there another reason that you would want to use that heavy threaded rod still.?
[mike-mack.blogspot.com]
April 27, 2012 12:38AM
Very nice! I had been thinking about a rack and pinion for a little while. If the gear's teeth mesh with the rack well then there should be no backlash - but that will also depend I guess on the geometry of the teeth, moreso when you're going at very high speeds.
Unfortunately for me I'm getting in on RepRap a little later, and I'm still waiting on the rest of my parts to arrive before I can make one.
One thing that I was thinking about though is durability. I plan to maximize speed, accuracy, and repeatability with my machine, and so if at high speeds I'm wearing down a printed rack or gear really fast, then that would be a problem. Keep us updated! What's the maximum speed you can achieve reliably with your X axis now?
April 27, 2012 01:39PM
100 mm/s. Still improving. The pinion stops much harder than a belt. But I it seems to be very accurate.
April 27, 2012 03:42PM
> still.?
In rack_herringbone.scad, line 16 you find: innerRadius=3.1;//shaft radius, in mm.
Just change the radius to the value you need.
May 03, 2012 02:56PM
Meanwhile I replaced the belt on the y axis too. Now the printer runs without belts.
May 04, 2012 04:59AM
Do you use lubrication on the racks?
May 04, 2012 09:51AM
I guess the next step in evolution would be to replace the rack with a rigid chain actuator, so that the footprint of the printer is the same as with belts.
May 04, 2012 11:11AM
Very interesting. Have you needed to lower your acceleration?
May 04, 2012 12:07PM
No.
May 04, 2012 12:17PM
> acceleration?
I should, because the printer tries to jump off the table.
May 04, 2012 02:15PM
amazing. as I said on thingiverse I'm very curious to see how this shapes up over extended use but not needing to buy belts is awesome. even if it wears down I'd rather print a new tooth bed than buy belts. for $16 you can print quite a few tooth beds and melt down the old abs into a rubber mold for re-use.
I can easily see a different printer design where the motor moves rather than the rack being a much closer basis for a fully printed printer minus electronis.
great work.
May 06, 2012 09:37PM
It seems like it would be a fairly simple redesign for the y axis to move the motor to the center and have the rack mounted to the bottom side of your print table. This would eliminate having the rack stick out so far from the rest of the printer.
May 06, 2012 11:33PM
I had a design with the rack on the platform. [www.youtube.com]
It was setup where you could pull the platform all the way out which was pretty nice for access when removing prints.
May 07, 2012 10:54PM
I can only offer a suggestion based on CNC lathe experience. I once tried to convert a lathe that used a rack and pinion drive. At first it was great, as the teeth wore the back lash became horrible. Hopefully the lack of load on the printer will make wear much less of an issue. Those appear to be square teeth, you should consider using an involute tooth. It will wear more even.
The solution I came up with was to use a spring loaded rubber coupling. Basically a tight fitting X coupling with rubber in the middle. The problem was the software had to account for it. It took to many steps to get it moving. And every direction switch required a pause to let the rubber decompress. The final solution ended up being a ball screw that was pretensioned. So a true 0 backlash system. The X coupling could work well for this and take some of the shock out of start and stops. Something like this. [www.lovejoy-inc.com]
August 25, 2012 03:53AM
Now my Prusa Mendel and my Huxley both run with rod and pinion. smiling smiley
October 21, 2012 01:40AM
Where do you get your springs?
I love the rack and pinion idea. I have not rally seen this explored any further yet in the wild.
November 13, 2012 02:02AM
This idea needs to be applied to the Rostock printer. The darn thing will be mostly printed parts at that point.
November 14, 2012 11:13AM
Interesting thread as I found this Kickstarter offering their injection moulded printer using Rack & Pinion for X.
[www.kickstarter.com]
open | download - 111412_Cap001.jpg (49.7 KB)
November 14, 2012 11:34AM
@prober: I am not sure, if it is a good idea to carry the x-stepper on the x-carrier. Better keep it light.
@idolcrasher: I bought a set of 200 different springs on ebay.
November 14, 2012 04:01PM
good point,
wonder why they did that? Do the large machines use this method? They claim this design comes from their experiences with the larger equipement.
November 14, 2012 08:17PM
Prober: Probably to reduce footprint, otherwise you need to attach rack to the x carriage and it will protrude a lot with carriage near stepper position.
