power supply
May 05, 2012 12:15PM
HI
i got a new pc power supply a ATX 2 450 watt
the one before 350 watts works great ' im trying to heat the bed faster . =)
when im trying to heat up my bed no problem but when im turing on the extruder the heat bed
stop working !??
i was connection all yellow wire toghter - 7 wires
black wire 7 wire bundle ?
sense wire connect as well
i read somthing about pmw is their a way to deal with that i dont now in this pc power supply have this thing ?
is their a way to know that ?
any suggestions please ??
thank you for helping
Re: power supply
May 05, 2012 11:44PM
sounds like you have a short, use a multimeter to check the resistance
[mike-mack.blogspot.com]
Re: power supply
May 06, 2012 04:03AM
HI
thank you helping =)
i dont have a problem with my other poer supply .
could it be a wrong connection that i did on the new power supply
i have coonect all the 12 -1 to one bundle and ignured the 12v - 2 only one wire.... could it be that one
what about to even the load between the 12 v rail and the 5 volt rail ??
regards
elidor
Re: power supply
May 06, 2012 04:41AM
I don't know how many times I have to say this in these forums.
PC PSUs WILL NOT WORK PROPERLY WITHOUT A LOAD ON THE 5V RAIL.
Use a 10R power resistor or a 12V car brake light bulb, or similar. I.e. about 0.5A and it will get hot.
Re: power supply
May 06, 2012 05:49AM
HI nophead
respect hearing from you =)
thanks alot ill do that .
elidor
Re: power supply
May 06, 2012 01:44PM
I've seen PC PSU's that require as much as a 2A load on the 5V line to get a consistent 12V from the 12V line.
They're not worth the effort IMO unless you have specific knowledge it will work without a load and some do.
Re: power supply
May 07, 2012 08:55PM
Elidor Wrote:
> HI
What kind of heat be do you have?
350 watts should be plenty. If your looking to heat your bed faster you'll need to increase voltage. PCB heatbeds can safely have their voltage increased in my experience. I've run mine at 19v without any problems. Keep in mind your bed will draw more power at higher voltages. I've been using a 120 watt universal laptop adapter-[www.amazon.com]
don't set it above 19v or less if you heatbed has less resistance than mine (prusa mk1 heatbed). I tried 20v and the adapter stoped working. To much draw.
This is pc psu I use-[www.amazon.com]
It works fine without a load on the 5v rail. I just put a jumper on the green and black wire on the 20 pin connector.
Re: power supply
July 16, 2012 05:53AM
Hi
thank you all =)
so i have a ressistor 10 ohms 5 watt
is this will do the work to get 0.5 amp load on 5 volt rail
thanks
Re: power supply
July 16, 2012 06:54AM
Yes. It will get very hot so be careful not to touch it.
Re: power supply
July 16, 2012 07:18AM
Hi nophead
great...... thank you alot =)
