best layer hight for a 0.4 nozzle ? May 18, 2015 03:05PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 03:24PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 03:25PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 03:46PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 04:38PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 05:16PM |
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 08:55PM |
Admin Registered: 12 years ago Posts: 1,063 |
Nikki81
Thank You I will run some test prints tomorrow. I have been using 0.2 layer hight and have been getting very good prints but it is very slow it took over 5 hours to print just the body of a wades extruder but not having any experience am not 100% sure if that is just how long it takes.
Thanks Nikki
Re: best layer hight for a 0.4 nozzle ? May 18, 2015 11:36PM |
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 02:24AM |
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 06:37AM |
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 10:34AM |
Nikki81
I think I have found the perfect setting I have been testing 0.25 with the 0.5 test cube.
[attachment 54896 IMG_0601.JPG]
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 04:11PM |
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 05:14PM |
He meant make sure your layer height is evenly divisable by the steps and pitch of your Zaxis threaded rod.Quote
lunarkingdom
his calipers say mm ;-)
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 05:19PM |
Floyd
If he is using a 5mm threaded rod with a .8mm pitch then at a layer height of .25mm he will have an error of -.8mm over 10cm
M5 threaded rod likes layers that are even. Instead of .25mm (that would give rounding issues) .24mm or .26mm would be fine.
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 06:23PM |
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 06:27PM |
Floyd
Personally ive used auto bed level with and without and I found I had more issues and grief with it on the printer.
I manually leveled the bed using a machinest indicator and have not had to worry about a unleveled bed since.
Auto bed level in my opinion has its places but its no replacement for a properly setup printer.
Re: best layer hight for a 0.4 nozzle ? May 19, 2015 09:20PM |
Re: best layer hight for a 0.4 nozzle ? May 20, 2015 03:31AM |
Re: best layer hight for a 0.4 nozzle ? May 20, 2015 05:00AM |
cristian
So almost nobody uses bed autotramming/leveling? I am asking because if you use it then your "virtual Z axis" is probably no longer vertical and the above precaution would no longer be so simple to apply.
Re: best layer hight for a 0.4 nozzle ? May 20, 2015 04:00PM |
Re: best layer hight for a 0.4 nozzle ? May 22, 2015 11:26AM |
Re: best layer hight for a 0.4 nozzle ? May 22, 2015 01:31PM |
Re: best layer hight for a 0.4 nozzle ? May 22, 2015 02:39PM |
Re: best layer hight for a 0.4 nozzle ? May 22, 2015 04:29PM |
Re: best layer hight for a 0.4 nozzle ? May 22, 2015 04:41PM |
