e3d v6 problem May 31, 2015 09:50AM |
Re: e3d v6 problem May 31, 2015 11:12AM |
Re: e3d v6 problem May 31, 2015 11:22AM |
Re: e3d v6 problem May 31, 2015 01:33PM |
Re: e3d v6 problem May 31, 2015 03:09PM |
Re: e3d v6 problem May 31, 2015 09:12PM |
trist077
just looked on youtube and there should be a small bolt and washer holding thermistor in guess what mine never had one but i guess that what you get for buying secand hand
Re: e3d v6 problem May 31, 2015 11:48PM |
frankvdh
trist077
I have 2 Chinese hot ends, both claiming to be E3D V6. One has a small screw and PTFE washer to hold the thermistor in, the other doesn't. On the second one, the heater cartridge and thermistor wires are taped together, so that when the cartridge is in place, the thermistor is held in its hole.
I don't know which of these is the genuine E3D V6 design.
Re: e3d v6 problem May 31, 2015 11:49PM |
trist077
ordered the new pt100 from esd online a lot more accurate than a thermistor so hopefully this will sort it though
but now the thermister is unpluged from the board the displa is still showing 200 i unplugged the heatbed too that says 0 degrees
Re: e3d v6 problem June 01, 2015 01:12PM |
Re: e3d v6 problem June 01, 2015 02:56PM |
Re: e3d v6 problem June 01, 2015 09:40PM |
Re: e3d v6 problem June 02, 2015 08:44AM |
Re: e3d v6 problem June 02, 2015 11:38AM |
Re: e3d v6 problem June 02, 2015 01:00PM |
Re: e3d v6 problem June 03, 2015 02:49AM |
Re: e3d v6 problem June 03, 2015 09:34AM |
Re: e3d v6 problem June 03, 2015 09:40AM |
Re: e3d v6 problem June 03, 2015 02:02PM |
Re: e3d v6 problem June 03, 2015 02:22PM |
Re: e3d v6 problem June 03, 2015 02:57PM |
javitopia
Although the pt100 is more precise and have a wider temperature margin in the e3d page it clearly states that they are only compatible with makerbot electronics and that they would require additional electronics to plug it in a ramps.
Re: e3d v6 problem June 03, 2015 03:38PM |
Re: e3d v6 problem June 03, 2015 03:55PM |
