An all metal hot-end design (Lots of Pics) July 28, 2012 09:37AM |
Re: An all metal hot-end design (Lots of Pics) July 28, 2012 11:45AM |
Re: An all metal hot-end design (Lots of Pics) July 28, 2012 05:34PM |
Re: An all metal hot-end design (Lots of Pics) July 28, 2012 08:50PM |
Re: An all metal hot-end design (Lots of Pics) July 28, 2012 10:19PM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 03:31AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 05:03AM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 05:46AM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 06:26AM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 08:28AM |
The heater-block and cooler block are very tight together, only 4mm or so, and that gap is not getting much airflow, there is a good chance that some radiation/convection is playing a part in taking heat from the hot side to the cold side.|
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 09:33AM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 12:46PM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 05:49PM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 07:12PM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 07:45PM |
Re: An all metal hot-end design (Lots of Pics) July 29, 2012 09:48PM |
I like it but how would we make the fans spin backwards? Simply reversing the voltage to the fans only works with permanent magnet motors from the limited testing I did a few years back.Quote
NumberSix
One possible solutions might be to be able to control the fan direction. They can cool the heat-sinks when air flows in either direction (we can debate which direction cools better), so when you are first printing you suck air up, then when you want to cool the work you blow air down! Just a wacky suggestion!
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 05:13AM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 02:51PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 02:58PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 04:00PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 05:02PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 07:05PM |
It's a quickly evolving design. Keep at it!|
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 07:16PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 07:37PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 07:48PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 07:49PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 08:03PM |
Re: An all metal hot-end design (Lots of Pics) July 30, 2012 09:06PM |
Re: An all metal hot-end design (Lots of Pics) July 31, 2012 01:39AM |
Re: An all metal hot-end design (Lots of Pics) July 31, 2012 03:47AM |
