Baby sized reprap August 02, 2008 08:36AM |
Re: Baby sized reprap August 02, 2008 10:09AM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Baby sized reprap August 02, 2008 11:51AM |
Admin Registered: 17 years ago Posts: 7,879 |
Each corner (3off) would be: A base bracket A top bracket which holds the motor. Two vertical 8mm rods as guide rails. One threaded drive. A flexible coupler. A sliding carriage. Two parallel arms with magnets into HDPE cup bearings A central tool holder Six diagonal ties as we have now. A stationary build table at the base.
Re: Baby sized reprap August 02, 2008 11:54AM |
Re: Baby sized reprap August 02, 2008 03:25PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Baby sized reprap August 02, 2008 04:38PM |
Re: Baby sized reprap August 04, 2008 12:19AM |
Re: Baby sized reprap August 04, 2008 07:06AM |
Re: Baby sized reprap August 04, 2008 08:09AM |
Re: Baby sized reprap August 04, 2008 08:39AM |
Re: Baby sized reprap August 04, 2008 08:40AM |
Re: Baby sized reprap August 04, 2008 09:12AM |
Anonymous User
Re: Baby sized reprap August 05, 2008 03:17PM |
Re: Baby sized reprap August 05, 2008 03:56PM |
Re: Baby sized reprap August 05, 2008 04:50PM |
Instead of 3mm welding rod, you could use nylon fishing line
The 3 positioning servos could be chained together robot-arm-style with the extruder mounted on the last segment
Re: Baby sized reprap August 05, 2008 08:11PM |
Re: Baby sized reprap August 06, 2008 03:35AM |
Re: Baby sized reprap August 13, 2008 06:18AM |
Re: Baby sized reprap August 24, 2008 02:20PM |
Re: Baby sized reprap August 24, 2008 06:53PM |
Re: Baby sized reprap August 25, 2008 03:24PM |
Even worse: if it can only print darvin, it'll get's useless if Mendel is coming around.
Re: Baby sized reprap August 25, 2008 04:19PM |
Re: Baby sized reprap August 25, 2008 07:50PM |
Re: Baby sized reprap August 25, 2008 11:27PM |
Re: Baby sized reprap August 26, 2008 05:14AM |
I don't get this. If you graft a little SD card reader onto your baby reprap machine you could hold the complete parts descriptions of dozens of generations of reprap machines. A 1 GByte SD card costs about $10 and they get lots bigger than that.
A Pic 24F would do the job pretty easily and handle the display and keyboard
Re: Baby sized reprap August 26, 2008 07:40AM |
Re: Baby sized reprap August 26, 2008 07:55AM |
Re: Baby sized reprap August 26, 2008 08:11AM |
Re: Baby sized reprap August 26, 2008 08:33AM |
Re: Baby sized reprap August 28, 2008 05:39AM |
