heater resistor not fitting in the larger hole in the heater block November 15, 2012 03:09PM |
Re: heater resistor not fitting in the larger hole in the heater block November 15, 2012 05:20PM |
Re: heater resistor not fitting in the larger hole in the heater block November 15, 2012 05:34PM |
Re: heater resistor not fitting in the larger hole in the heater block November 16, 2012 10:14AM |
Re: heater resistor not fitting in the larger hole in the heater block November 16, 2012 01:21PM |
Re: heater resistor not fitting in the larger hole in the heater block November 16, 2012 01:29PM |
Re: heater resistor not fitting in the larger hole in the heater block November 16, 2012 03:47PM |
Re: heater resistor not fitting in the larger hole in the heater block November 17, 2012 03:52AM |
Re: heater resistor not fitting in the larger hole in the heater block November 17, 2012 08:06AM |
Re: heater resistor not fitting in the larger hole in the heater block November 17, 2012 08:20PM |
Re: heater resistor not fitting in the larger hole in the heater block November 19, 2012 06:21AM |
Re: heater resistor not fitting in the larger hole in the heater block November 20, 2012 03:59PM |
