Layers seperating
March 29, 2013 01:59AM
I have been having problem since I switched to a 0.25mm nozzle. My layers don't seem to stick to each other real well and some sections can be pulled apart with little effort. Does anyone know why and how to fix it?
Re: Layers seperating
March 29, 2013 02:19AM
Higher temp, slower speed. Been using a .25mm for about 5 months. If you can set up an enclosure for your printer, it will help greatly.
Edited 1 time(s). Last edit at 03/29/2013 02:20AM by Dirty Steve.
March 29, 2013 03:18AM
Ok. I will try that. I have been printing at 225-230c so ill try slower, been running at 100-200mm/s
March 29, 2013 10:14AM
Did you lower layer height/thickness with smaller nozzle? I use .2-.25 with a .35 J-head.
Thingiverse ID Alan1279
March 29, 2013 10:27AM
Ya, I lowered the layer height to 0.2mm for my printing, thats what caused this problem I was having I guess. I used to print with a 0.5mm nozzle and switched it out for better detail (0.25mm). I spent a lot of time trying to figure out that I had to lower the layer height, as KiSSlicer doesn't warn about that and Slic3r did. Now I just need to dial in a decent draft speed and check that my lower quality speed works and my layers don't separate.
March 29, 2013 11:17AM
.2mm is the upper layer height limit for a .25mm nozzle. If you don't mind the print time increase, drop down to a .15mm layer.
.1mm is my most used layer height.
March 29, 2013 12:37PM
I have a makergear .25mm and it works great. Usually print 180-185 Degrees (PLA), .15 Layer height, and anywhere from 40mm/s to 125mm/s... but slower speeds do work better. My layers never come apart.
-Nick
