X,Y,Z Steps Calibration Help
April 02, 2013 07:47AM
I have finished building my Prusa I3 and am working on calibrating it but I'm having issues. Here is my setup that I'm using.
Prusa I3 Single Frame
Azteeg X3 with Marlin firmware
Kysan 1124090 Steppers
GT2 Belts with 20 tooth pulley
5mm x .80 pitch threaded rods for Z axis
Repetier Host Software
Here is my problem. Steppers operate fine and in proper direction. I set the steps in the software through firmware EEPROM configuration and saved it. When I give the command to move 100mm it moves maybe half that. This is for all axis. I used the formula steps = motor_steps_per_rev * driver_microstep / belt_pitch / pulley_number_of_teeth for the X,Y axis and came up with this 200*16/2/20=80
For the Z axis I used this formula steps = motor_steps_per_rev * driver_microstep / thread_pitch and the results 200*16/.80=4000
Can anybody tell me what I'm missing.
Re: X,Y,Z Steps Calibration Help
April 02, 2013 08:03AM
Check your stepper drivers and make sure they are set for 1/16 stepping!
It looks like they are set to 1/8 stepping.
One revolution of a 1.8° stepper is 200 steps * 16 = 3200 steps/revolution.
For GT2 (2mm) belt and a 20 tooth pulley 1 revolution = 2 * 20 = 40 mm/revolution.
3200 steps/revolution * 1 revolution/40 mm = 80 steps/mm.
Since this isn't happening then something is NOT as calculated and that can only be your microstepping or that your steppers are not 1.8° steppers. The Kysan 1124090 Steppers are however 1.8° steppers so that leaves your microstepping as the culprit.
Wrong jumper, wrong switch position, bad contact...
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
April 02, 2013 08:43AM
rather than calculating by the pulley teeth should you not calculate by the circumference of the pulley around motor shaft? 200*16steps* 1mm/ pulley circumference should give the steps per mm.
something like that anyways.
April 02, 2013 08:52AM
jamesdanielv
No, (steps * microstepping) / (teeth * pitch) is EXACT and CORRECT.
Bob Morrison
April 02, 2013 01:38PM
rhmorrison
Surely 1/32 if they are moving half as much as they should.
April 02, 2013 01:53PM
Makes sense it does support 1/32 stepping. In the X3 documentation it says to install shorting jumpers on m1, m2, and m3 for 1/16 stepping, which is what I did. Anyone else using this controller that can verify that.
April 02, 2013 07:43PM
The azteeg X3 takes pololu style stepper drivers. Most of those only go down to 1/16 stepping, but those based on the drv8825 chip support 1/32 stepping. To get 1/16 stepping from that chip, you want to install only the third microstepping jumper.
April 02, 2013 07:55PM
Which I assume you mean m3?
April 02, 2013 08:07PM
Yes.
April 03, 2013 02:47AM
nophead
eye popping smiley YES, that is of course what I meant to type... grinning smiley
Bob Morrison
Prusa i3 Microstepping
October 30, 2013 08:39AM
Hello,
which is Prusa i3 Microstepping
Is it 1/8 or 1/16 or 1/32
WIll it effect the Output Quality?
Regards,
Chandru
Edited 1 time(s). Last edit at 10/30/2013 08:40AM by gm_chandru.
October 30, 2013 09:22PM
Resurrecting zombie threads really isn't the best way to get information. Starting a new thread is a better way to go.
You want your setup to micro step at what ever it's finest resolution is. You then calculate the firmware numbers for that step resolution. If you paid the money for a 1/32 step setup, you might as well use it. The finer the resolution the smoother the acceleration. It has no noticeable impact on precision.
