ABS Heated Bed Warping July 16, 2013 10:54PM |
Re: ABS Heated Bed Warping July 16, 2013 10:58PM |
Re: ABS Heated Bed Warping July 16, 2013 11:00PM |
Re: ABS Heated Bed Warping July 16, 2013 11:38PM |
Re: ABS Heated Bed Warping July 16, 2013 11:51PM |
Re: ABS Heated Bed Warping July 17, 2013 03:23PM |
This is probably the easiest way to significantly improve your ABS prints as all you need is a garbage bag. With my MK2 heat bed at 110C, the "chamber" temperature is over 40C measured at the top of the bag (it would be much higher in the print volume). This really helps combat warping and also blocks all drafts that can negatively affect the consistency of your perimeters.
should really improve your ABS prints.
Re: ABS Heated Bed Warping July 17, 2013 03:36PM |
Re: ABS Heated Bed Warping July 17, 2013 04:12PM |
I recently replaced it with a quality ATX power supply and now I can get to about 135C (thermistor reading) bed temp within my "garbage chamber", though this takes ages
. However, I now place a square piece of cardboard over my bed while it is heating and it can easily reach 135C! Cardboard is a great insulator and is the easiest way to speed up bed heating.
The bed of my Prusa is very bent and the borosilicate glass seemed to conform to the shape of my bed. By the time I scrapped it I could only print in an area of about 50mm x 50mm! On the whole, I think 2mm to 3mm float glass is the way to go.|
Re: ABS Heated Bed Warping July 17, 2013 07:40PM |
Re: ABS Heated Bed Warping July 17, 2013 08:54PM |
Re: ABS Heated Bed Warping July 17, 2013 09:02PM |
Re: ABS Heated Bed Warping July 17, 2013 11:59PM |
Re: ABS Heated Bed Warping July 18, 2013 12:09PM |
Re: ABS Heated Bed Warping July 18, 2013 12:18PM |
Re: ABS Heated Bed Warping July 18, 2013 03:16PM |
Re: ABS Heated Bed Warping July 20, 2013 12:58AM |
Re: ABS Heated Bed Warping July 20, 2013 01:02AM |
Re: ABS Heated Bed Warping July 20, 2013 01:44AM |
Re: ABS Heated Bed Warping July 20, 2013 02:34AM |
Re: ABS Heated Bed Warping July 20, 2013 09:35AM |
Re: ABS Heated Bed Warping July 20, 2013 02:32PM |
Re: ABS Heated Bed Warping July 20, 2013 10:21PM |
Re: ABS Heated Bed Warping July 20, 2013 10:22PM |
Re: ABS Heated Bed Warping July 21, 2013 12:59AM |
Re: ABS Heated Bed Warping July 21, 2013 03:52AM |
Re: ABS Heated Bed Warping July 21, 2013 02:30PM |
Re: ABS Heated Bed Warping July 21, 2013 05:34PM |
Re: ABS Heated Bed Warping July 21, 2013 08:07PM |
