how do i know my ramps have bootloader
August 21, 2013 11:13PM
how can I find out is my aragiuno have bootloader installed in it or not ? I bought a prusa online and the seller didnt answer my question. I trying to figure out the which pin for what and does it have bootloader inside it and which one is it ( marline , sprinter ....)
Re: how do i know my ramps have bootloader
August 22, 2013 12:55AM
bootloader is installed by default if you have a mega 2560 on an arduino board call the arduino mega 2560. download the arduino ide at www.arduino.cc
August 22, 2013 03:54AM
Probably you misunderstood the bootloader definition. You probably want to know the firmware type, version.
Connect the Arduino/RAMPS with your computer, start your Host software e.g. Repetier-Host, configure the Printer in Printer Settings and click Connect. You will see the info in the log windows.
Edited 2 time(s). Last edit at 08/22/2013 03:59AM by flurin.
3D Printing :: bit-by-bit - Thingiverse
August 22, 2013 08:35PM
I got these errors when I use connect on the repetier-host , what does it mean ? my prusa cant print anything I have the led light on when connect the usb onto my computer and no no led light when I unplug it and only plug the power supply from the wall plug.
20:34:20.915 : 串口号错误confused smileyystem.IO.Ports.SerialErrorReceivedEventArgs
20:34:20.930 : 串口号错误confused smileyystem.IO.Ports.SerialErrorReceivedEventArgs
August 22, 2013 10:20PM
system.IO.Ports.SerialErrorReceivedEventArgs ? are you on a windows 8 system. do you have the latest .net framework installed?
[www.microsoft.com] winxp
[www.microsoft.com] win7
[www.microsoft.com] win8
google around a bit, this seems to be a known issue with .net framework versions not being current.
if arduino ide is installed and you launch serial monitor there should be a response if marlin firmware is loaded.
Edited 1 time(s). Last edit at 08/22/2013 10:21PM by jamesdanielv.
August 23, 2013 09:34PM
i have framework 4.5 install and when i connect to printer on serial monitor there is nothing
August 25, 2013 04:29PM
is the board powered up first? (external powered, and usb powered.)
