How to set up ATX Power supply September 21, 2013 06:10AM |
Re: How to set up ATX Power supply September 21, 2013 07:23AM |
Re: How to set up ATX Power supply September 21, 2013 10:06AM |
Re: How to set up ATX Power supply September 21, 2013 02:54PM |
Re: How to set up ATX Power supply September 21, 2013 05:59PM |
Re: How to set up ATX Power supply September 21, 2013 06:31PM |
Re: How to set up ATX Power supply September 21, 2013 09:18PM |
Re: How to set up ATX Power supply September 22, 2013 01:05AM |
Re: How to set up ATX Power supply September 22, 2013 05:27AM |
Re: How to set up ATX Power supply September 22, 2013 06:32AM |
Re: How to set up ATX Power supply September 22, 2013 06:48AM |
Re: How to set up ATX Power supply September 22, 2013 10:35AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: How to set up ATX Power supply September 22, 2013 04:10PM |
Re: How to set up ATX Power supply September 23, 2013 07:37AM |
Ok, well having the RAMPS 1.4 I don't think that will work.
Re: How to set up ATX Power supply September 23, 2013 07:21PM |
Traumflug
Cut off the disk power connectors and clamp the wire ends into the RAMPS connectors. Same procedure as with any power supply.
Re: How to set up ATX Power supply September 24, 2013 11:19PM |
Re: How to set up ATX Power supply September 25, 2013 08:32AM |
How would I tell which connector is the disk power.
Re: How to set up ATX Power supply September 25, 2013 10:13AM |
Re: How to set up ATX Power supply September 25, 2013 04:55PM |
The Hobbyking PS35 can supply a constant 25A at 14v (Max 350w).
Re: How to set up ATX Power supply September 25, 2013 07:32PM |
Re: How to set up ATX Power supply September 25, 2013 09:53PM |
Re: How to set up ATX Power supply September 26, 2013 08:29AM |
