Water cooled all metal hotend
October 02, 2013 08:41AM
I used the following:-
A stainless steel hypodermic tube (available at Amazon and Mcmaster's) 0.084" ID
Two m6 brass bolts with holes drilled lengthwise
a copper heater block with holes for a 12v/40w stainless steel heater cartridge, a thermistor and for the stainless steel tube and a small hole for a 3 mm bolt to hold the cartridge in the block
a copper tube with a hole drilled through
a 6 mm brass dome nut for the nozzle with a .5 mm hole drilled in.
6 mm copper washer between the dome nut and the heater block
I soldered the heater block to the one brass bolt(head partially filed away) with the stainless steel tube through both, then the copper tube to the stainless tube and then the other bolt that will be used to fasten the hotend to the mounting plate and the bowden tube.
I used silver solder with a 56% silver content with a handy gas flame and stainless steel flux.The inside of the stainless steel tube and all areas that were not supposed to be soldered were covered with milk of magnesia(one can use tippex as well). The Milk of Magnesia not only keeps the silver solder from flowing beyond the joint, but it seems to protect the stainless from getting that hard black coating from being heated.
After cleaning the hotend the tube was polished with a string and brasso to clear the inside of the tube and the heater cartridge and thermistor installed. I used thermal paste on the cartridge.
The heater block insulated on top with cuttlefish bone.
More pictures on the website listed below.
Edited 2 time(s). Last edit at 10/02/2013 08:45AM by Xabbax.
You only learn when you change your mind.
[www.deltaprinter.co.za]
Re: Water cooled all metal hotend
October 02, 2013 01:06PM
thanks for posting btw
Please explain what is the purpose of cooling the hot end?
October 02, 2013 01:33PM
Keeps the filament from sticking inside the tube leading to the hotend.
Post a video of it in action please.
October 02, 2013 03:09PM
Drilling a 0.5mm hole in that domed nut sounds hard..(well through the M6 nuts too) Yet i havent seen anyone describe it. Suppose is just a matter of getting a tiny drill and a stable drill stand?
October 02, 2013 04:37PM
Nice, Xabbax! Thanks for sharing! smiling smiley
Jasper1984
There is a description of a simple way to do this here.
October 02, 2013 06:28PM
You might want to check out the picture of the prototype of the hot end I will be releasing. You can see a picture of it on my website a www.vanguardinnovations.us We are still sorting out minor problems, but it looks like tuning issues, nothing serious. it has printed polycarbonate, and PLA successfully.
October 02, 2013 07:52PM
I have to Laugh!
A Hotend --- that has to be Cooled?
One can't isolate a HOT area from the mechanics (that like to be cool) without active cooling
you got to be kidding --- and NOT doing a good design?
Pour power in to heat a section of the Hotend and pouring more energy in to pull out heat to cool it down
WHATS NEXT --- Active Cryogenic cooling?
October 02, 2013 09:37PM
You design many hotends, cozmicray? The thermal break is a challenging part in all of them, and the source of many problems.
Even commercial units use active cooling - see the Stratasys Dimension teardown linked from this thread.
Plenty of people think water cooled hot ends are a good idea. Here are two other examples besides Xabbax's:
RepRapPro Water Cooled Hot End
Greg Frost's Water Cooled Hot End
October 03, 2013 01:25AM
Nice job on that water cooled hot end, it is simple. I like it.
Yvan
Singularity Machine
October 03, 2013 01:26AM
im personally changing mine to water cooled,
I have 20kws of solar, I dont give a F about cooling a " hotend", it gives results,
October 04, 2013 11:20AM
No I haven't designed a 3D printer hot end
but
I have been involved in a lot of designs for spacecraft
Keeping hot things from getting cold, keeping cold things from getting hot
Isolation and insolation is the key Preventing heat flow in or out.
Why does a QU-BD type extruder, with hotend 1.5" from mechanics work so well
--- without water cooling
A fan blowing on gear and motor provides good cooling
All these Rep Rap extruders are NOT DESIGNED by Thermal engineers
but kludged together by garage mechanics
I have nothing against Garage inventors
--- but we really need here is some real design, development and testing
of a thermal extruder design.
A water system added to a printer --- another thing to leak --- fix ---- control
Ten years from now we will laugh at todays extruders
October 04, 2013 01:38PM
If you are going to talk about the designers with those words, then, come up with a design, if not, just shut up and go play with your spacecrap.
> but
> spacecraft
> cooling
> Thermal engineers
> extruders
October 04, 2013 01:50PM
Serious?
October 04, 2013 02:52PM
I've heard not so good things about the QU-BD design. How come it doesn't work so well?
I have to add that a big part of the RepRap formula is simple functional designs that can be fabricated around the world in peoples home workshops with simple tools. They will always win out over anything more refined and demanding too fabricate.
BTW, googling "Le Schtroumpf Grognon" might provide some amusement.
Yvan
Singularity Machine
October 04, 2013 03:33PM
@Xabbax
Well done smiling smiley
Your design looks like a very accessible way to build a DIY water-cooled hot end. Keep up the good work!
@cozmicray
cozmicray
but
I'll be honest and say that you clearly have no idea what you are talking about.
It can be a good thing to question someone's designs, but do not just jump in and start attacking a person's design if you do not yet understand every aspect of it.
First of all, you claim that the QUBD hot end works very well without water-cooling even though it is known to be one of the most unreliable all metal hot ends on the market. However, the failure of the QUBD extruder is not a result of the fact that it is not water-cooled, but rather due to the lack of internal polishing on the SS heat break, which an essential facet of reliable all metal hot ends.
The hot end is arguably the most complex aspect of 3d printers as it deals with the tricky business of melting and extruding plastic filament. To understand the design features of hot ends, you must have a basic knowledge of the thermal properties of thermoplastics, specifically the way they behave at their glass transition temperature (Tg). At temperatures below Tg, thermoplastics retain their hard, solid consistency (as we see in plastic filament). As the temp rises above the Tg of the thermoplastic, its consistency changes from solid to rubbery and it begins to expand. If you continue to increase the temperature to the melting temperature (Tm) the consistency will change from rubbery to liquid. The plastic filament enters the hot end in its solid state and exits in its liquid state. Within the hot end there is the crucial thermal transition from solid to rubbery to liquid. In its rubbery state, the plastic will expand and grip the inside of the hot end and will resist extrusion/retraction and thus increase the likelihood of the hot end jamming. As a result, the hot end developer makes an effort to mitigate this problem by reducing the area that the rubbery plastic can grip and cause jams (by shortening the transition zone), and by reducing the friction between the rubbery plastic and the interior walls of the hot end (by polishing the internal pathway within the hot end). This rubbery filament problem is more apparent when extruding PLA which has a very low Tg (about 60C).
Ok, RepRap hot end designers may not be professional thermal engineers, but they certainly take into account the basic thermal properties of metals and thermoplastics. Every successful all metal hot end design (regardless of whether it is water-cooled or air-cooled) has a similar set of design features: a short thermal break that is internally polished and machined from a metal with low thermal conductivity (SS is most often the metal of choice), a "hot side" that consists of the heat block which is machined from a metal with high thermal conductivity (brass, copper, aluminium), and a "cold side" which consists of either a heat sink machined from a metal with high thermal conductivity (usually aluminium) with a fan blowing over it or some sort of water-cooled sleeve.
Each of these aspects of reliable all metal hot end design is specifically aimed at regulating the temperature of both the "hot side" and "cold side" and preventing heat flow across the thermal break. Since you claim have worked in designing spacecraft, I will give you the benefit of the doubt and assume that you know all of these basic properties of metals and can now understand the workings of Xabbax's design.
It's ok to not understand how something works, but just don't try to justify your ignorance by putting down a design that you can't fathom.
Eric
October 04, 2013 04:36PM
RP Iron Man, it couldn't have been said better ! Thank you for setting things straight.
October 04, 2013 06:20PM
@knowbusiness
No problem smiling smiley
It's best if everyone understands the basics of hot end development so that people can judge designs according to their theoretical functionality rather than aesthetics/hype. This was a huge problem when Jo released his original PrusaNozzle which had some serious design flaws but happened to look beautiful and was of course made by the designer of the Prusa Mendel! Many people ended up buying Jo's hot end based on the aesthetics/hype which unfortunately resulted in a lot of unhappy people and a chip on Jo's reputation. Bad result for all parties involved sad smiley Even though the PrusaNozzle MKII design seems to address these flaws, many people are steering clear of it based on the negative experience of MKI users. It's unfortunate, but hopefully people can now use this information to more accurately judge the merits of a design.
I plan on releasing my own all metal hot end design sometime soon and I hope that people in the community will be able to provide constructive feedback, not the kind of ignorant responses that resemble cozmicray's posts.
BTW I am impressed with your work in hot end development. While I have never used an SG2 hot end, I have heard great things about it smiling smiley
Keep up the good work everyone!
Eric
Edited 1 time(s). Last edit at 10/04/2013 06:24PM by RP Iron Man.
October 04, 2013 06:40PM
Thank you nic0laz for your contribution to this thread
You must be one award winning designer
I didn't realize that basic design could NOT cross over different design problems
> > but
> > spacecraft
> cold
> 1.5"
> > cooling
> > Thermal engineers
> design,
> > extruders
October 04, 2013 06:49PM
@nic0laz
nic0laz
I must say, while cozmicray did not question the design in the most civilized way, this response did not help the misunderstanding in any way whatsoever. Even if you think someone is being unreasonable on the forums, please do not blatantly insult them without addressing the issue at hand. It is counterproductive as it takes us off the topic and destroys the supportive atmosphere that we have in RepRap.
Eric
October 04, 2013 06:56PM
I have done many multi hour prints with an all metal QU-BD extruder
Yes I have had extruder problems
but
I did not have a problem with the hotend heating the cold mechanics
and overwhelming the motor and gear air cooling
RP Iron man pointed out all the details of hot extrusion, which I have read before
and all those little gotchas in the process can ruin a nice print.
I would like to see a good reliable hotend.
As I said after some years of trial and error and/or good design
We will laugh at or admire the extruders we are using now
Just like we laugh at / admire dot matrix printer heads
Sorry for seeming to dink Designers
Serious?"
October 04, 2013 07:21PM
So what kind of problems did you experience with your QU-BD extruder?
Yvan
Singularity Machine
October 05, 2013 07:38AM
Over around one year i developed my own hotend. Nothing fancy, ultimately a variation of many other designs that came up over time.
My aim was
1. Reliability
2. No active cooling
3. Easy to manufacture
4. Inexpensive
It turned out it is rather easy to do. No air or water cooling needed.
I think cozmicray has a point, the more complex a design is the more can (and will) go wrong, not to mention that it becomes more expensive.
Cheers
Björn
October 05, 2013 08:42AM
> My aim was
> 1. Reliability
> 4. Inexpensive
> Cheers
> Björn
How about some pictures, maybe a link, anything. A simple statement may be as simple as your hot end, it doesn't do much.
October 05, 2013 09:30AM
Sorry, the footer i put in the profile does not seem to be added.
Please check here
[my.bonkers.de]
Video of it printing can be found here
[www.youtube.com]
[www.youtube.com]
October 05, 2013 11:23AM
Srek, very nice
October 05, 2013 02:12PM
Srek, yes complexity is an issue. At the same time, the original design by Wabbax has no plastic. The plastic parts are the first to fail, especially if you are trying to print higher temperature plastics. Personally, I've been having difficulty sourcing PEEK, but maybe I'm not looking in the right places.
I also designed a very robust and jam free hot end that needs no active cooling. It has one PTFE part, so it is not on par with the all metal hot ends.
Yvan
Singularity Machine
October 05, 2013 09:05PM
I got a mBot Mk 7 all metal QU-BD type extruder hot/cold end
Pix MK7-1 shows it with controllable cooling fan to cool PLA below nozzle
Seems like now even mBot uses plastic parts
I have QU-BD extruder that has screw that is used adjust pressure
to push filament against hobbed gear
without a roller or ball bearing in there it does't work very well
There is no adjustment for filament against hobbed gear
Pix MK7-2 shows metal idler bearing in extruder
Pix MK7-4_grinder shows a problem with it grinding up filament
Pix MK7-3_Nylon shows death by nylon (taulman 618}
no solvent for nylon --- used a bernz torch to melt it off killed the thermistor and cart heater
when I used the hotend again with new heater, thermistor, nozzle never worked the same
Mostly ---PLA not sticking to bed (Glass, eched glass, Blue tape) --- part getting knocked off
layers not bonding together
Inconsistancy - maybe 4 prints to get acceptable part
Air and the large stainless steel mounting plate between hot end and extruder mechanics,
fan and extruded aluminum on mehanics keep it cool.
Motor gets hot on long runs just from stepping --- a CPU cooler with thermal paste strapped directly to top of motor solved that
Rock solid Hotend temperature shown by Repetier-host graphs
and measurement with external thermocouple and meter
Even have had external thermocouple and meter on cold side to measure temp Max, I saw 43 deg C
I really think my problems are PLA, ABS, Nylon, Polycarb crystalizing in brass nozzle and impedding squirting good plastic nerdel
--- I have logs, pictures ---- still an art NOT a science???
Hope that answers some questions
open | download - MK7-1.jpg (22.5 KB)
open | download - Mk7-2.jpg (22.9 KB)
open | download - MK7-3_Nylon.jpg (22.4 KB)
open | download - MK-7-4_grinder.jpg (23.2 KB)
October 05, 2013 09:32PM
ok so not sure if this has been said, but the mk7 hot end is actively cooled, just like a water cooled hot end. its just the water cooling makes it a lot easier to control the temperature of the filament before it goes into the melt zone, and by controlling this you can have more precise control over how much force it takes to push filament out of the hot end. for example if you wanted to run some really nice small prints with a small nozzle, 0.35mm, you would run cold water through the hot end, if you have a big ass nozzle, say 1mm you would want to actually run warm water through the hot end in order to melt the plastic more quickly and reduce the amount of force required to push the filament through. by running your water through a mainfold with a peltier unit attached it is possible to both heat and cool the water very easily and predictably, even with an enclosed build chamber you can control the cold end temperature. with a simple fan and heat sink this is simply not possible.
October 06, 2013 12:54AM
cozmic, very interesting photos and comments! What went wrong with the nylon, it didn't stick to the platform and blobbed around the hot end?
Yvan
Singularity Machine
October 06, 2013 08:09AM
@MattMoses thanks for the link.
A fan doesnt pose much technical complexity. It is literally directly connected to the 12V.. Besides maybe people will want some suction getting rid of some smells/toxic fumes.(Even though those seem to be easily in the safe range) That'll involve air currents that can be used for cooling aswel anyway.
Water cooling does pose more technical complexity? Maybe doing it with electronics by measuring near the filament at the cold end and controlling air speed might be another way of doing it. Not that water is a bad solution at all, the electronic solution is much more complex/higher threshhold in initially developping, but lower complexity when it already exists.
