Print speed limits? October 22, 2013 01:22PM |
Re: Print speed limits? October 23, 2013 07:01AM |
Re: Print speed limits? October 23, 2013 10:23AM |
Re: Print speed limits? November 13, 2013 09:58PM |
Re: Print speed limits? November 14, 2013 02:10AM |
Re: Print speed limits? November 14, 2013 01:13PM |
Re: Print speed limits? November 14, 2013 01:27PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Print speed limits? November 14, 2013 06:32PM |
nophead
That is only true when you ignore retraction where you need much higher speed and the same torque. This extruder used a tiny stepper but it was too slow at reversing to get blob free prints.
Re: Print speed limits? November 15, 2013 01:19PM |
Looking at Ultimaker prints, there are often loads of wisps of filament, as the extruder can't stop the flow quick enough when moving from one part of the object to another.
So I'm not sure that a bowden cable unit is ultimately going to give the highest speed, without some loss of quality or need to post process the print.
H bots also look interesting as X and Y motors are also fixed, but the trade off is a very long belt as well as twisting / slack in the Y bearings, causing minor errors in print head position.
Re: Print speed limits? November 15, 2013 03:34PM |
Re: Print speed limits? November 15, 2013 09:17PM |
but I'm still not sure it's any better and a conventional XY head type, ie where one motor is still on a carriage, because the Y gantry looks like a substantial bit of metal, albeit aluminium
Re: Print speed limits? November 16, 2013 03:28PM |
Re: Print speed limits? November 16, 2013 05:48PM |
Admin Registered: 11 years ago Posts: 1,063 |
rogerclark
Hi Crispy1
I've no experience of H bots, but all the designs, pictures and videos I've seen, made it looks like the components needed to be quite rigid because of the twisting forces.
Perhaps this only applies to the frame.
Would it be possible to have a H bot with plastic carriages and 8mm smooth rods?
Re: Print speed limits? November 16, 2013 06:26PM |
Re: Print speed limits? November 16, 2013 08:04PM |
Re: Print speed limits? November 16, 2013 11:18PM |
Any idea why this geometry isn't widely used ?
Re: Print speed limits? November 17, 2013 04:55AM |
Re: Print speed limits? November 17, 2013 05:02AM |
crispy1
Getting plates laser cut doesn't give you this design flexibility, and it's probably more expensive for a 1-off machine.
crispy1
L-beams are going to be harder to work with, primarily because you're going to be drilling lots of holes in them which gets old after a while
Re: Print speed limits? November 17, 2013 04:36PM |
Re: Print speed limits? November 20, 2013 06:09PM |
Admin Registered: 13 years ago Posts: 730 |
crispy1
I've asked for those features to be ported to Marlin or some other RepRap firmware, but no one seems interested in undertaking this.
