Getting the filament to initially stick
October 25, 2013 02:46PM
I'm having a problem with my printer.
If I'm lucky enough to get it to stick at the beginning, the print goes great, and the part is hard as a rock to get off the build platform.
But getting it to stick, and not drag around the first couple centimeters of filament usually means I have to restart the print a couple times until I'm lucky.
Example
https://www.youtube.com/watch?v=af8snH15RwQ#t=8m40
@8:45
How do I get the printer on that first initial blob to stick to the plate?
Re: Getting the filament to initially stick
October 25, 2013 06:10PM
What are you printing with and on?
If PLA on glass then I found that cleaning the glass with alcohol (I use car de-icer) between prints is 100% reliable.
George
Anonymous User
October 25, 2013 09:48PM
Hairspray
October 26, 2013 03:25AM
My chemist sells "nail varnish remover pads"
A little box of pads impregnated with nail varnish remover.
I wipe the bed every other print with one. As far as I can make out, it's oil/grease that's the enemy.
Once I touched the bed to feel the temp, then started to print and had a finger shaped unstuck bit in the middle of the first layer.
That convinced me.
Oh, and first layer slow, I print my first layer very slow (option in slic3r)
Cheers,
Dave
October 26, 2013 08:44PM
Sounds like your nozzle gap is too wide.
_______________________________________
Waitaki 3D Printer
Anonymous User
October 27, 2013 03:28AM
I'm using blue tape which works perhaps too well. Lemon juice on glass works too.
October 27, 2013 05:39AM
UHU glue stick works as well
