Wind Turbine Blades from a 3D Printer November 25, 2013 01:25PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 01:39PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 02:05PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 05:08PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 05:28PM |
Admin Registered: 13 years ago Posts: 730 |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 06:07PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 06:39PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 07:22PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 07:44PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 07:49PM |
cozmicray
What is the problem with using ABS, Nylon, Polycarb pieces?
Why must they be sintered?
Low RPM doesn't matter --- centrifical force put on blade,
energy in blade ---- at what speed will it rip through buildings and bodies?
Why do you need "instant" blades?
Unreasonable development time?
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 08:02PM |
Re: Wind Turbine Blades from a 3D Printer November 25, 2013 08:23PM |
bobc
I suspect that the surface finish of the blades is crucial to their efficiency, given that the operation of an airfoil wholly depends on airflow over the surface.
I assume that a smooth surface is vital (but with luck a rough surface could actually help - kind of a million to one shot). Even SLS creates a quite rough finish. So a printed airfoil would need to be coated or otherwise smoothened in a predictable way to get a consistent efficiency. Regardless of mechanical strength, I would want to thoroughly investigate the requirements for surface finish first. Could be an acetone bath will do it, but I would like to know otherwise the whole idea could be a non-starter.
Re: Wind Turbine Blades from a 3D Printer November 26, 2013 05:22AM |
bobc
Re: Wind Turbine Blades from a 3D Printer November 26, 2013 07:13AM |
Re: Wind Turbine Blades from a 3D Printer November 26, 2013 03:29PM |
T0mmm
could you put a section of your blade on here / thingiverse so one of us can try to print it?
It sounds like quite a large item to print, in terms of time required and also material required - what will the density of the part be? (i.e completely solid, or just a hollow shell)
my printbed area is 340mm wide * 205 deep * 205 tall so i may be able to squeeze something in...
However I'm still a bit of a novice!
Re: Wind Turbine Blades from a 3D Printer November 26, 2013 04:46PM |
Re: Wind Turbine Blades from a 3D Printer November 27, 2013 03:57PM |
Re: Wind Turbine Blades from a 3D Printer November 29, 2013 04:43PM |
Re: Wind Turbine Blades from a 3D Printer December 05, 2013 10:17AM |
Re: Wind Turbine Blades from a 3D Printer December 05, 2013 09:14PM |
Re: Wind Turbine Blades from a 3D Printer December 06, 2013 11:21AM |
Zerker
I always thought the root of the blade, was where it attached to the hub, if so the above design would not help aleviate the problem of PLA not being strong enough to endure the Thrust force at the root.
Re: Wind Turbine Blades from a 3D Printer December 07, 2013 05:54AM |
Re: Wind Turbine Blades from a 3D Printer December 08, 2013 02:01PM |
Re: Wind Turbine Blades from a 3D Printer December 09, 2013 11:30AM |
Re: Wind Turbine Blades from a 3D Printer December 10, 2013 06:44PM |
Re: Wind Turbine Blades from a 3D Printer December 12, 2013 09:41AM |
Re: Wind Turbine Blades from a 3D Printer December 12, 2013 10:53AM |
