Round shape is not exactly round..
January 20, 2014 03:41PM
Hi everybody,
I am not sure if it's my settings or the printer, but since a while, my cylinders and round shapes don't print really smooth.. at all.
Anybody familiar with this problem?
Prusa mendel i2
Natascha
Edited 1 time(s). Last edit at 01/20/2014 03:51PM by Nsverhagen.
Re: Round shape is not exactly round..
January 20, 2014 05:00PM
That's XY ripple, try a print at 10 or 20mm/s. What speeds are you running at?
Edited 1 time(s). Last edit at 01/20/2014 06:08PM by Dirty Steve.
January 20, 2014 06:34PM
You should check your belt tensions and make sure they are quite tight (like a badly tuned guitar). Loose belts will do that. If your belts don't make a sound when you pluck them, they are too loose.
Also, use a drop of oil regularly on each axis to make sure they run smooth.
January 20, 2014 06:36PM
Also, make sure all your bolts / nuts are tightened, especially the extruder.
January 20, 2014 06:49PM
this is caused by non smooth motion where extrusion is slightly misplaced.
zip tie those bushings in place. there is too much leverage against them to even be held in place by the kapton tape. also switching eventually to a 4 bushing x carriage instead of the 3 will help as well. in the mean time look at your jerk settings, i can't remember if they should be higher or lower, but you definitely want to play around with jerk settings, and then reduce speed.
reroute the wire if possible the wire may be impeding motion and causing non smooth motion.
also check belt tension.
Edited 2 time(s). Last edit at 01/20/2014 06:52PM by jamesdanielv.
January 21, 2014 06:04AM
Strange, I already tried some of these ideas, but maybe it's a combination solutions
I changed the following things:
- Tighten the belts
- Zip-tie the bushing
- Lower the speed
- WD-40 on each axis
I will get a 4th bushing when I get the chance.
I guess this will help, the printer doesn't make as much noise as before for sure. I will see next time I print something round.
Thanks a lot!
Natascha
January 21, 2014 06:09AM
Don't forget to play with your firmware "jerk" settings as recomended by jamesdanielv.
January 21, 2014 06:33AM
Where can I find this setting?
I use Slic3r and Repetier..
January 21, 2014 07:28AM
Nsverhagen
In the part you upload on the arduino, Configuration.h
You are probably using Marlin.
January 21, 2014 08:16PM
Don't use WD-40. It's a de-greaser and cleaner as well as lubricator and the LM8UU bearings will get damaged and full of sludge. Use a really light bearing lubricant like you would use for router bearings.
January 22, 2014 02:19AM
Oh, didn't know that. Thanks
I use sprinter and am trying to put new firmware on my sanguinololu, but I have a few problems with it. Hope I can get it working fast, until that I can't change the configuration...
