Pause command for G code? January 26, 2014 11:44PM |
Re: Pause command for G code? January 27, 2014 12:16AM |
Re: Pause command for G code? January 27, 2014 12:28AM |
Re: Pause command for G code? January 27, 2014 12:32AM |
Re: Pause command for G code January 27, 2014 02:14AM |
Re: Pause command for G code? January 27, 2014 03:31AM |
Re: Pause command for G code? January 27, 2014 06:49AM |
Wiki
G4: Dwell
Example: G4 P200
Re: Pause command for G code? January 27, 2014 08:56AM |
lazzymonk
Silly me. Should not reply to forum posts while half asleep. I re read and realised what your trying to do.
You want G4 Dwell.
From the wiki
Wiki
G4: Dwell
Example: G4 P200
so if you were to put G4 P5400000 at the start of your gcode it would sit there and do nothing for 1.5 hours.
Thats assuming 5400000 isnt too big a number.
Re: Pause command for G code? January 27, 2014 09:37AM |
Re: Pause command for G code? January 27, 2014 12:40PM |
Re: Pause command for G code? January 27, 2014 12:41PM |
That may be good if you need a short period for something. But having the extruder stay fully heated for an hour and a half may results in oozing, or if nothing else, cooking the filament.Quote
lazzymonk
You want G4 Dwell.
Re: Pause command for G code? January 27, 2014 12:43PM |
Re: Pause command for G code? January 27, 2014 02:09PM |
cdru
lazzymonk
You want G4 Dwell.
Plus, what was the original purpose of needing the pause? If it's from a safety aspect in case something overheats or worse catches fire, then just sitting there with both heat sources on but the printer not moving doesn't increase the safety.
Re: Pause command for G code? January 27, 2014 02:53PM |
