Why does it seem few care about print strength and how to compare it? January 27, 2014 12:47AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 12:58AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 01:30AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 01:39AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 03:10AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 05:22AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 06:43AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 09:48AM |
Sure thing. I will create a new thread for this purpose (Once I get all my data from upcoming tests). I will upload my raw data in spreadsheets, with test & printing conditions.Quote
jzatopa
If you are going to continue doing testing on your own you will really need to make sure you track everything. Some of the main factors are design, print material type, print material brand, temp controlled environment (oven), acetone treatment, print temp and infill.
Could you add that information to the data you are sharing?
jzatopa
If you could also post your methodology you might find a few other people on here willing to test what they have.
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 09:54AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 09:55AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 09:56AM |
Srek
Thanks for the info, i were actually looking for something like this.
PET (like T-Glase) might really be interesting to you, it is lightweight and seriously strong while much easier to print than nylon and less warp prone than ABS.
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 09:57AM |
jamesdanielv
I always used tensile strength to compare plastics performance. not that it is perfect, and it really does not tell me much.
this tells me that bonding strength is different for each plastic.
now I'm curious as to why, is it temp difference or something else.
I actually found this data very useful.
graphs are nice, but seeing video of some sort of Gage or measurement device is more convincing. I'll try to find a link to a video for an example and edit this post later
I would encourage anyone working on such things,
thanks for your contribution!
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 10:02AM |
aduy
Ive found that getting proper adhesion is fairly consistent amongst different materials, for example all thermoplastics perform better when they are dried before printing, except for pla using a heated build chamber always helps with adhesion. Ive printed some large 12x12x12 pieces in abs and the warping forces actually made a split along the xy plane about half way through a 50 hour print, even with a 120c heated bed. After that waste of time i decided to setup a heated build chamber running at about 90c, the abs came out of the nozzle like hershey's chocolate syrup, and the print had no warp, infact it kind of drooped a bit in the infilled sections, to the point where it really needed a better pattern.
so from my discoveries there are three things that can make any print stronger in abs/nylon/polycarb: dry the filament out all the way, Use a heated bed and build chamber, if possible use a solvent to further increase the bond strength of the plastic with a vapor bath. also to doecrease warping without a heated chamber you need to increase the layer time.
DCM can be used for polycarbonate but look up the msds first. for nylon tetrafluoropropanol is the solvent to use.
If you were going to be doing this a lot it might be worth making something like this so you arent working directly with the solvents. you might even be able to fit your printer in there, if you can't fit it you can even make into a fun project "reprap in a bottle".
[www.laboratory-supply.net]
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 10:05AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 10:24AM |
jamesdanielv
strantor :
I just viewed it,
here is a video with an analog Gage.
[www.youtube.com]
those analog gages tell a lot to people.
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 11:07AM |
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 12:11PM |
strantor
aduy
I did experiment with acetone DURING ABS printing. I had acetone evaporating in (sealed, but not pressure-sealed) crock pot, with a tube plumbed to my print head. The idea was to get acetone infused between layers to improve layer adhesion. Results were poor. The acetone condensed in the tube and dribbled out. I considered enclosing my printer and having ABS vapor inside, but that would eat my printer and create a very unsafe pressure chamber full of explosive atmosphere with a low flash point.
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 05:43PM |
To be clear, I was not talking about post processing in a vapor bath. I was talking about piping in vaporized acetone WHILE printing, so that it gets between the layers and nit just on the outside. Is that what you're talking about too?Quote
aduy
strantor
aduy
strange, my experiments went well, i was able to smooth out a layer height of up to 1mm, and totally bond some other pieces that I left over night in a low concentration vapor bath without heating.
Re: Why does it seem few care about print strength and how to compare it? January 27, 2014 05:54PM |
Ralf
I did some testing last year, but I haven't had the time to move on with a more systematic test.
It was fun to build the rig, but very time consuming to actually do some tests.
[ralfsfablab.blogspot.dk]
I have mostly done tests with ABS, which just confirms that higher temp=higher strength, within reason of course.
Re: Why does it seem few care about print strength and how to compare it? January 28, 2014 04:20AM |
Re: Why does it seem few care about print strength and how to compare it? January 28, 2014 07:27AM |
Ralf
I had the steel laying around from another project, so it was only the load cell and an instrumentation amplifier (INA125P) that I had to buy, so that was ~40€ in total.
Of course it is completely undocumented but if there is any interest, that wouldn't be too dificult.
It is lacking deflection measuring, but a potientiometer, a string and some more code, should be able to do that.
Re: Why does it seem few care about print strength and how to compare it? January 28, 2014 07:45AM |
Re: Why does it seem few care about print strength and how to compare it? January 28, 2014 11:02PM |
Re: Why does it seem few care about print strength and how to compare it? January 28, 2014 11:28PM |
Re: Why does it seem few care about print strength and how to compare it? January 29, 2014 12:04AM |
Admin Registered: 13 years ago Posts: 730 |
Re: Why does it seem few care about print strength and how to compare it? January 29, 2014 12:51AM |
Re: Why does it seem few care about print strength and how to compare it? January 29, 2014 12:07PM |
Good point. I will use a round bar henceforth.Quote
A2
The faceted sides of the Allen wrench create stress risers, best to use a round steel rod for consistent readings.
Understood, this the purpose of the "wire halo" on top to evenly distribute weight on both side of the allen wrench. On the bottom, the allen wrench is blocked under the machined vise jaws, which are (should be) perfectly perpendicular to the drill quill. So, in (my) theory, there should be no appreciable loading more on one side than the other.Quote
A2
I'm not able to see how you are mounting the Allen wrench to evenly distribute the tensile load.
But side loading will generate poor test results.
You're right, in a perfect world it should be a more controlled linear pull than what I am doing by hand. But the way I see it, if it's going to break @ 120 lbs, it should break @ 120 lbs whether that number is arrived at in a perfectly linear increase, or in a stepped increase with possible occasional minor tension releases. But I'm not a thermoplastics engineer and I could be wrong. Am I wrong?Quote
A2
The rate that the force is applied should be mechanically controlled. Use a lead screw with a motor.
I'm having trouble visualizing this. If a gas shock behaved like a non-newtonian fluid; if it had no inherent force of it's own, was free to move (very little resistance) at low speed and only resisted quick changes acted upon it, then yes, I can see that working. However the traditional shock absorber like in an automobile suspension or trunk hatch movement dampener, does have it's own inherent force. It's like a gas-powered spring. I've replaced the shocks in my car, both suspension and trunk, and can attest to the fact that these things are quite hard to compress. I think they would greatly skew the measurement. ...unless you're talking about a different type of shock that I'm unaware of. Can you elaborate?Quote
A2
Test: the spring force gauge can be dampened with a gas shock (from an automobile).
That's a good point I suppose, but at some point more data is not not more helpful data. I feel like the test already involves a cumbersome amount of data. I have to split the results up into several graphs in order for it to make immediate sense; otherwise it's just colorful collage. I'm not sure if one more graph would be of any help. I will wait until I get feedback from the test results that I plan to post this weekend, and see if that's something that people want to see, or if it's "good enough."Quote
A2
In addition to tensile testing with the lay, and against the lay,
print a scarf joint lay pattern (i.e. print at an angle), it should increase the strength.
I think I know where you're going with this, and that is the reason why I made the test pieces a full 10cm long. I figure people will complain about the print time, but with a test piece that long, it should be adaptable to a wide array of test fixures without the fixures needing a micron-level spec on the distances involved. The longer test piece is more forgiving on the dimensions of the fixture. I simply place "whatever is left" of the test peice, after one or both of the eyelets have been ripped out, under the jaws of my vise, and adjust the vise to the point where it's almost clamping the piece, but not clamping it. This gives a reasonably repeatable distance; I've never measured the distance, but it's always about the same. As far as round profiles, probably not gonna happen. I don't see the point for machining anything special for this test. I don't think it would have enough effect to make it worthwhile, but again, you sound like you know more about it than I do, so if you have a convincing reason why, I'd be glad to listen.Quote
A2
Bending test should support the object with round profiles separated with a known distance.
Again I'm not able to see how you were supporting the test samples.
I don't completely agree. I whole-heartedly agree that all these things should be recorded, but not that they should be controlled. We are not testing only the polymers, we are testing the process as well. Maybe your process involves dried filament, temp controlled printing environment, et. al., and maybe mine doesn't; maybe my test pieces with water-logged filament, printed on my back porch in a blizzard outperform yours (of course, not going to happen, just a hyperbolic example). If I had matched all your controls, there would be no indication of what process variables had beneficial impact on my success or failure.Quote
A2
Consistency:
Filament should be dried before use.
Test samples should be printed in an enclosed temperature controlled environment.
The test samples should also be dried before testing, and/or pretreated in a humid environment.
All machine and environmental factors should be recorded.
Test speciemens dimensions should be measured, and the weight recorded before testing.
Thanks for the tip, but I don't think I'll be using dog bone samples unless further testing convinces me that I need to (I will be thinking about it). I designed the process to test things that we (or maybe just me) care about (real life). How often do you actually care about the tensile strength of a piece? That's an honest question, not a rhetorical one. For me, I didn't care about tensile strength until I bent the fingers of my 3D printed hand backwards, and the hinged joints ripped out (tear-out strength). This is actually more a function of layer adhesion than tensile strength. So I designed the test to give me an indication that I cared about, and I think it's pretty good at that. The actual value of the test result is not as important as it's relative (to other people's #s) value.Quote
A2
Dog-bone test samples would make for an improved test specimen,
as it would allow you to clamp the ends with more force away from the region that is going to fail, and is a standardized form.
You can print geometric forms in the center of the dog-bone, but this is not a 1:1 comparison to the holes on the end with a metal rod.
Dog-bone test samples thickness can be increased, possibly this would allow you
to see if there is a nonlinear response, or inconsistency in your method of fabrication,
and to clue you in on to what thickness would work best for your application.
I wouldn't abandon your test specimen design (i.e. holes at the ends) as it allows you to test for tear-out strength,
which is important to know for hardware mounting.
That stuff is mostly above my head, and I don't care enough about it right now to invest the time to educate myself about it. Going down that rabbit hole would be a huge distraction from my ultimate goal, to make a prosthetic hand. But, I share this test with the world, in the spirit of open-source development. I encourage others to perform the test. To standardize on a test, any test (this test, if nothing better shows its face). I hope, that those who share in the interest and in the spirit of open-source development will pick up the ball an run with it. You, or anybody else who wants to test these things, is more than welcome to do so. I would love to hear the results, even if I don't fully understand them. I only ask one thing; If you're going to use my STL file, don't modify it. it is a constant.Quote
A2
Flexural/bending, creep, wear/abrasive, impact, drop test, U.V. ozone, conductivity, and
solvent, acid/alkaline, lipid, blood contact, and other types of tests will
also help you to better understand the device design, and the material choice.
I definitely will. I have already built the hand a couple of times and destroyed it a couple of times. That's what prompted me to design the test. It's just too time consuming to build a whole hand just to destroy it. Once I settle on the best material and best process I can find, I will build the hand again and destroy it again, just to see what it takes, and then build it again.Quote
A2
Ultimately you are concerned with product performance in the real world.
Dog-bone specimens is just a starting point to help you understand the material and manufacturing process.
Eventually you should be testing the final product under real world conditions.
Re: Why does it seem few care about print strength and how to compare it? February 03, 2014 09:44PM |
Re: Why does it seem few care about print strength and how to compare it? February 10, 2014 09:27PM |
[...]And that's why I'm contacting you. If anybody knows how to print the strongest 3D prints with Taulamn polymers, it's Taulman. So, I'm asking you to print my .STL file [on a RepRap-style printer with your best possible known settings and polymer] and send me the prints so that I can test them and publish the results in open forum. This will give us a "baseline." As you can see, I've already posted some test data on your products, and I don't know if I'm doing them justice. I'm giving you the chance to up the ante, and I'm offering free advertising.
[...]And that's why I'm contacting you. If anybody knows how to print the strongest 3D prints with ProtoPasta polymers, it's ProtoPasta. So, I'm asking you to print my .STL file [on a RepRap-style printer with you best possible known settings and polymer] and send me the prints so that I can test them and publish the results in open forum. This will give us a "baseline." As you can see, I've already posted some test data on Taulman's products. I don't know if I'm doing their products justice. I'm giving you the chance to up the ante, and I'm offering free advertising.
