Mendel Thick Sheet SVG?
November 25, 2009 07:17PM
Does anyone know where I can get a Ponoko-ready SVG of the laser cut thick sheet for Mendel? They don't accept DXF files unless you have a pro account, which costs ~$40.
-Adam
"Day breaks, but decay soon follows."
VDX
Re: Mendel Thick Sheet SVG?
November 26, 2009 03:08AM
... maybe you can convert them from DXF to SVG with Inkscape?
Viktor
November 26, 2009 02:48PM
I tried, but Ponoko requires that all lines for cutting be colored blue; I don't know how to change line colors in Inkscape.
VDX
November 26, 2009 04:16PM
Hi Adam,
i have installed in german, so my functions are named different, but you should find the colouring menue either when selecting the objects, clicking the right mousebutton (context-menue), select something like "filling and contour" (fourth selection from bottom) and then the middle tab named like "colour of the contourline" or such. Then draw the blue slider to the right or type 255 as value.
Or in the main menue, tab "Objects" the first selection "filling and contour" ... then the same as above ...
Viktor
November 27, 2009 09:59AM
Thanks for the tip! I'll go edit the files as soon as I finish breakfast.
Sorry I didn't reply earlier, it was Thanksgiving, and I had a very busy day (busy with food!)
Adam
December 23, 2009 07:31PM
> as value.
> as above ...
When performing the above it just doesn't work.
It shows the contour as being blue but displays as back.
If you FILL with Blue then part of the outline is blue and part is black.
How do I color the contour blue?
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
December 24, 2009 10:03AM
I managed to put the SVG in order by hand editing the SVG (XML) file.
Now everything appears to be correct but Ponoko.com still won't accept the file.
Have sent it to them and asked what is wrong with it.
Has anyone ordered the thick sheet for Mendel from Ponoko?
And if so, how much does it cost?
