LM8UU ball groove orientation February 14, 2014 09:42AM |
Re: LM8UU ball groove orientation February 14, 2014 10:53AM |
Re: LM8UU ball groove orientation February 14, 2014 01:37PM |
Re: LM8UU ball groove orientation February 14, 2014 05:07PM |
Re: LM8UU ball groove orientation February 14, 2014 07:26PM |
Re: LM8UU ball groove orientation February 14, 2014 07:46PM |
Re: LM8UU ball groove orientation February 14, 2014 07:55PM |
Re: LM8UU ball groove orientation February 14, 2014 08:04PM |
Admin Registered: 13 years ago Posts: 730 |
Re: LM8UU ball groove orientation February 15, 2014 11:21AM |
Dirty Steve
I am getting a lot of chatter from my x-carriage bearings
It's a chatter in my X-carriage, it shows up in my print surfaces
Re: LM8UU ball groove orientation February 15, 2014 11:31AM |
Re: LM8UU ball groove orientation February 15, 2014 11:38AM |
Admin Registered: 11 years ago Posts: 3,096 |
A2
Are you using a harden precision ground steel shaft?
Small diameter bearings are sensitive to slight variation of the shaft diameter.
Orientated at 45 deg is good.
[www.heason.com]
Switch to sintered bronze bushings, or the plastic coated aluminum bushings
Re: LM8UU ball groove orientation February 15, 2014 11:52AM |
Re: LM8UU ball groove orientation February 15, 2014 12:40PM |
Re: LM8UU ball groove orientation February 15, 2014 01:03PM |
Admin Registered: 11 years ago Posts: 1,063 |
Re: LM8UU ball groove orientation February 15, 2014 02:07PM |
Re: LM8UU ball groove orientation February 15, 2014 04:48PM |
A2
@thejollygrimreaper:
Make a fixture to hold the Teflon.
Teflon deform very easily in a vice or 4 jaw chuck.
You might be able to get away with a ridged PVC pipe fit to the O.D..
I've found a parabolic drill works best with plastic.
Center drill, then pilot hole drill the diameter of the drill webbing, before going to size.
When boring Teflon, the plastic tends to push away from the cutter.
To prevent cutting a linear grove after you bore or drill through, stop the cutter, remove the part from the fixture,
and then push the drill through in the direction that you started drilling.
You might have to take multiple passes, or trial different size drills to get the diameter you desire.
Don't let the tool spin idly in the bored hole, the plastic will heat up and expand creating a barrel shaped bore.
MACHINING PLASTICS
[doc.nit.ac.ir]
Re: LM8UU ball groove orientation February 16, 2014 05:27PM |
Dirty Steve
I just upgraded my steppers and I am getting a lot of chatter from my x-carriage bearings, which has always been there, but more so with the motor upgrade.
What is the best way to have the bearings rotationally oriented? I have the LM8UU riding on the rods so that the ball grooves in the bearing are at 45 degrees to vertical/horizontal. Is this the correct orientation for the bearings or should they be perpendicular to vertical/horizontal? I can't find any reference to this online. I have the bearings in press fit holders and they will be a little work to rotate.
Re: LM8UU ball groove orientation February 16, 2014 06:27PM |
Re: LM8UU ball groove orientation February 16, 2014 07:30PM |
Re: LM8UU ball groove orientation February 16, 2014 08:04PM |
thejollygrimreaper
thats for a high-ish quality japanese bearing, not the 50cent stuff we tend to get
