Printer turns off mid print!!! February 15, 2014 01:58PM |
Re: Printer turns off mid print!!! February 16, 2014 03:55AM |
Re: Printer turns off mid print!!! February 16, 2014 07:05AM |
Re: Printer turns off mid print!!! February 26, 2014 03:46PM |
waitaki
Probably!
If, for example, the hot-end resistor shorted to the heater block, then I would think that would trip the power supply. And seeing as you recently changed the hot-end....
yasrkasem
If you using a computer ATX PSU, Add some load on the 5v output as some ATX shutdown if no load on the 5v.
Re: Printer turns off mid print!!! February 27, 2014 08:22AM |
gmh39
yasrkasem
Would a simple LED be enough of a load? I assume you are talking about the red and black wires from the molex connectors, correct?
Re: Printer turns off mid print!!! February 27, 2014 08:44AM |
Re: Printer turns off mid print!!! February 27, 2014 09:06AM |
jamesdanielv
how much current does the hot end use? are you using a cartridge, or a resistor?
Re: Printer turns off mid print!!! February 27, 2014 10:12AM |
gmh39
jamesdanielv
Not sure on the current. I'll check when I get home. It uses a cartridge heater.
Is there a type of power supply I can use that doesnt require me to attach light bulbs to it to get it to work?
Re: Printer turns off mid print!!! February 27, 2014 10:26AM |
Re: Printer turns off mid print!!! February 27, 2014 10:34AM |
Re: Printer turns off mid print!!! February 27, 2014 10:36AM |
jamesdanielv
tjb1:
current used on the hot end and resistance of the hot end determines if there is a short or a defect in the heater cartridge. we all can read specs. we all know that something here is likely not working to its spec.
Re: Printer turns off mid print!!! February 27, 2014 11:26AM |
Re: Printer turns off mid print!!! February 27, 2014 12:58PM |
