Re: DIY tech shop defective hotends March 03, 2014 01:59AM |
Re: DIY tech shop defective hotends March 03, 2014 07:49AM |
A2
Coating the bore with thermal compound will improve the heat transfer, periodically replace it when it dries out.
Re: DIY tech shop defective hotends March 03, 2014 11:01AM |
TedMilker
There is no inexpensive thermal compound that won't break down at the temps we print at.
Re: DIY tech shop defective hotends March 03, 2014 11:44AM |
Re: DIY tech shop defective hotends March 03, 2014 02:04PM |
A2
TedMilker
I agree that some are very expensive, messy, smelly and can even equal the cost of a new hot end.
There are thermal greases for high temps, and at a low cost.
870°C (1600°F) Anti Seize Compound, Silver.
7g Pouch, $1.59/ each.
20g Stick Semi-Solid, $9.06/ each
[www.grainger.com]
@thatsme:
Another suggestion, to avoid using the thermal compound, you can peen with a punch and hammer the bore of the heater block,
only on the side that the set screw is located.
This will add minimal but additional metal contact with the nozzle, and snug up the fit.
Re: DIY tech shop defective hotends March 03, 2014 07:19PM |
tjb1
That's anti seize, not a thermal compound.
Re: DIY tech shop defective hotends March 04, 2014 07:19AM |
A2
@tjb1:
tjb1
Not all but Some anti-seize products can be used as a thermal compound.
In general the coefficient of thermal conductivity less than 0.16 is considered the start of being insulative.
Typically one material thermal property is not used to determine what material is best for a specific application.
For example, I use thermal effusivity, and thermal diffusivity to help me find a material for temperature sensitive applications.
I also use statistics to normalize, weight, and then combine material thermal, and physical properties, (e.g. density)
to help me contrast their differences, and find an appropriate material.
Thermal effusivity
[en.wikipedia.org]
Thermal diffusivity
[en.wikipedia.org]
An example of an anti-seize being used for heat transfer for a heater cartridge:
BNS Anti-Seize Cartridge Heater Coating
This high temperature electrically insulating and thermally conductive coating will minimize oxidation and
improve heat transfer from heater to the object being heated.
[www.tempco.com]
LOCTITE SILVER GRADE ANTI-SEIZE
Heavy duty, temperature resistant, petroleum-based lubricant compound fortified with graphite and metallic flake.
Inert, will not evaporate or harden in extreme cold or heat. For use in assemblies up to 1600°F (871°C).
[www.sealanddesign.com]
Materials used in high temp anti-seize compounds:
399°C (750°F), molybdenum disulfide.
400°C (750°F), Zinc.
871°C (1600°F), aluminum, copper and graphite.
982°C (1800°F), copper.
982°C (1800°F), copper, graphite, aluminum.
1204°C (2200°F), stainless steel, graphite, aluminum.
1316°C (2400°F), Nickel.
1316°C (2400°F), nickel, graphite.
1343°C (2450°F), graphite, calcium fluoride.
[www.neverseezproducts.com]
[www.henkelna.com]
[www.loctite.ph]
Re: DIY tech shop defective hotends March 04, 2014 07:37AM |
Re: DIY tech shop defective hotends March 04, 2014 08:18AM |
A2
tjb1
by your logic I can stuff a piece of silicone in there (because it can withstand high heat) and expect it to transfer it efficiently
Correct, silicone rubber, rtv thermal conductivity 0.272 is greater than 0.16, which makes it useful as a thermal conductor.
Re: DIY tech shop defective hotends March 04, 2014 08:27AM |
tjb1
Oh yes, why is it used for pot grippers? Because it is terrible at conducting heat.
Re: DIY tech shop defective hotends March 04, 2014 08:35AM |
A2
tjb1
Silicone is very useful as a thermal compound for high temperature applications.
Ceramic-based thermal grease has generally good thermal conductivity and is usually composed of a ceramic powder
suspended in a liquid or gelatinous silicone compound, which may be described as 'silicone paste' or 'silicone thermal compound'.
[en.wikipedia.org]
Re: DIY tech shop defective hotends March 04, 2014 10:00AM |
tjb1
The silicone is just to hold the conductors together.
a slightly heat conductor in itself (0.2 W/(m·K))
Re: DIY tech shop defective hotends March 04, 2014 10:26AM |
A2
tjb1
No silicone is not chosen only because it can suspend some thing.
It's also chosen because of it's ability to conduct heat, some silicone's are considered a thermal conductor.
A simple test that you can perform to experience the thermal conductivity of silicone:
Purchase a silicone mitt, and immerse your whole hand into boiling water up to your wrist,
you'll discover that you can't do it for very long before it burns you.
I have one of these gloves, and I tested this, I have first hand experience with it.
I've never used the glove because of how well it conducts heat, it's too painful.
Re: DIY tech shop defective hotends March 04, 2014 06:05PM |
tjb1
That is the exact reason that all the pot grippers, handles and anything made to grab moderately
hot objects is made from silicone because it doesn't transfer heat effectively.
Re: DIY tech shop defective hotends March 05, 2014 07:21AM |
Re: DIY tech shop defective hotends March 05, 2014 07:45AM |
A2
tjb1
Silicone can transfer heat well enough that 50% of a thermal compound is silicone.
Silicone has a range of properties, and when the thermal conductivity is >0.16 it's regarded as a thermal conductor.
An example of silicone used as an effective thermal conductor.
Designed to provide heat transfer, Good thermal conductivity (1.6 W/m-K)
DOWTHERM J Fluid for Superior Heat Transfer and Pumpability
DOWTHERM J heat transfer fluid is a mixture of isomers of an alkylated aromatic hydrocarbon fluid specially engineered for demanding low-temperature applications. It has long been used in the chemical process industry for cooling to-110°F as well as heating to temperatures as high as 600°F.
Re: DIY tech shop defective hotends March 05, 2014 07:48AM |
Re: DIY tech shop defective hotends March 05, 2014 10:28AM |
Admin Registered: 15 years ago Posts: 1,470 |
tjb1
3. Now you are using two different units... W/m-K vs W/m-C, you think you can slip that by with your bold and colored text that is suppose to push it as hard evidence?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: DIY tech shop defective hotends March 05, 2014 10:33AM |
tjb1
A2
tjb1
Keep living in your fantasy world, silicone is a terrible conductor. That is the exact reason that all the pot grippers, handles and anything made to grab moderately hot objects is made from silicone because it doesn't transfer heat effectively.
It seems you don't realize that the closer to 0 it is, the worse it is at conducting heat.
Re: DIY tech shop defective hotends March 05, 2014 02:11PM |
Mogal
Sorry, I really LOL'd at this!
TedMilker
Bottom line: The hotpad was a laugh riot
NewPerfection
Basically, we just want something that is a better heat conductor than air.
Virtually anything that has a better conductance than air
Re: DIY tech shop defective hotends March 06, 2014 09:07AM |
NewPerfection
it works far better than just wrapping the whole thing in Kapton tape like most people do and leaving air gaps everywhere.
Re: DIY tech shop defective hotends March 06, 2014 10:16AM |
TedMilker
NewPerfection
The smart ones fix the tolerance issues before wrapping in kapton so air gaps aren't an issue. Furnace cement and RTV silicone just make it look like way too much of a mess and your hotend look like it was assembled with trash.
Re: DIY tech shop defective hotends March 06, 2014 04:39PM |
TedMilker
NewPerfection
Re: DIY tech shop defective hotends March 07, 2014 12:54PM |
TedMilker
NewPerfection
Re: DIY tech shop defective hotends March 07, 2014 01:46PM |
Re: DIY tech shop defective hotends March 07, 2014 01:49PM |
You can try PTFE tape to seal the threads, but personally I would just call up DIY Tech Shop and have them replace the hot end for you.Quote
cfy7
Any ideas for a fix, or should I just call up Diytechshop?
Re: DIY tech shop defective hotends March 07, 2014 05:44PM |
Re: DIY tech shop defective hotends March 07, 2014 07:36PM |
cfy7
wrapping it with kapton tape for now to stop the leak.
cfy7
Says pretty much it'll just plug itself up with leaked plastic and
that they've tried this on one of their machines and it's worked decently for a while.
Re: DIY tech shop defective hotends March 07, 2014 08:09PM |
Re: DIY tech shop defective hotends March 07, 2014 10:19PM |
