Connecting a PSU power supply to an i3 Prusa XL
February 23, 2014 06:41PM
I've been building my first 3D printer, I'm just about to wire my power supply to RAMPS 1.4 and wanted to make sure I'm not going to destroy my electronics.
This is the back of the PSU output is 20A 12V
Here is the ramps board
Any advice would be greatly appreciated.
I don't know much about electronics, I'm not sure which outlets to connect.
Edited 1 time(s). Last edit at 02/23/2014 07:15PM by Corx.
Re: Connecting a PSU power supply to an i3 Prusa XL
February 23, 2014 07:18PM
I use these type of supply on all my RAMPS setups.
Connect positive to positive on each of the RAMPS and PSU connections and do the same with the negative.
Photo here of basic connections
If you are using Auto Bed Leveling you also need a 5 volt supply and that is best made by using a 7805 regulator chip connected to one of the RAMPS 12 volt connections, the third leg from the regulator is the 5 volt out put and that goes to the 5 volt connection on the RAMPS board.
[regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
February 23, 2014 11:06PM
Super simple response, thanks
February 24, 2014 06:03AM
Here is a drawing of the wiring layout.
[regpye.com.au]
February 25, 2014 05:47PM
Sorry, tangent from your post. What kind of PSU is that? Is there a name for the type that has the power distribution bar like that as opposed to an ATX PC PSU?
February 25, 2014 06:05PM
I don't think those power supplies have a standard name that describes them. They are 12V switching power supplies, usually used to drive LED's. The cheap Chinese ones off of eBay (and elsewhere) are really hit-and-miss when it comes to quality and longevity. Meanwell (and other name-brand manufacturers) make good quality supplies at a higher price. Something like this: [www.meanwell.com]
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
