Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 08, 2014 02:06AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 08, 2014 02:29AM |
The nut below the heat sink is a necessary part of the design that I don't really like. The nut is necessary to secure the SS nozzle to the heat sink but impedes the cooling of the "cold-side".
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 08, 2014 04:49AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 08, 2014 02:06PM |
regpye
Try using a cheap WebCam for taking the video. They are light, small and readily available. I bought a few for this purpose on ebay and they cost less than $10 each.
regpye
I am using a similar design, but not all metal. To adjust the zones I also use the adjustment of the threaded length, but to fix the thread and the heatsink (and also the aluminium heater block) I use set screws or grubs screws they are called here in Australia. Both the heater block and the heatsink are drilled and tapped with M3 to take the set screws and the set screws bite into the threaded length.
I lightly set them to start with, do my testings and when I am happy, I screw them in tight because I wont want to move them again. Down side is that they can be hard to adjust later if needed. Upside is that they are neat, easy to fit, cost effective, less weight, no heat transfer.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 09, 2014 11:41PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 10, 2014 12:21AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 10, 2014 01:44AM |
bstott
Wow! Looks Good! Almost like mine! ;-)
I built my new hot end from bits two weeks ago - End of Feb. 2014 - Motivated from a slipped out thermistor having created a Hot, Bubbling, Smoking, PEEK Melt Down!!!! [Factoid: Per Wikipedia -- PEEK "...melts around 343 °C (662 °F)..."]
Looking forward to see the Prometheus Indiegogo!
Brian
Pittsburgh, PA
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 10, 2014 02:59AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 10, 2014 03:14PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 10, 2014 09:45PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 08:05AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 03:19PM |
jameghino
The Argento hotend is 2 years old and the current version is 4 and as you can see the design is quite similar. I've been through many battles against filament types, transition zone, temperatures, and much more. If you need some feedback on the design or even machining, let me know.
Regards from Argentina
Javier
bstott
Regarding Prometheus -
On another thread -- A2 and I have had a short discussion about heat. It has come up that horizontal fins are not necessarily correct for the design of a passive hot end. I've reflected on this and have had experience with air cooled devices. A2 had already been discussing vertical heat flow so this brought to mind - fins radiating out from an item are generally intended to channel air flow from motion. Either motion of the device as in a motorcycle, auto or airplane engine head through the air or laminar air flow from an active fan. But, our hot ends are static. This means we ultimately will require a cooling fan to be truly effective. I remembered what happens to my previous use examples - the motors/engines, if not in motion - get hot. In the case of the auto and airplane, they overheat more slowly when static because they do have active fan systems in place. The auto's fan was connected to the flywheel in the case of an old Volks Wagen engine and a propellor in the case of an airplane.
What am I getting at? Well - our printers are not cruising through our environments - yet. They are sitting and the horizontal fin structure for cooling is demaning airflow to actually be efficient. They really do require a fan --- OR --- as A2 has suggested, in the other thread, we change the design to take more advantage of convective heat flow by using vertical fins. Then, if under heavy use, include the fans. Currently, the situation where horizontal/radial fins are working on a hot end wtihout a fan simply means that the delicate balance of the dissipative material's heat volume, external surface area and contact area to the heat source is sufficient to keep the hot ends functioning. (A Lucky guess has been realized.) Without the use of a fan, the present fins machined orthogonal to the riser are contributing very, very little to the actual cooling of the devices. That is ---- Again, we are currently being lucky ---- Not well engineered.
My little hot end - which is common to the designs we are discussing - requires a fan or it quickly heats and jams. It works. My best quesses, time and luck will show how well. It is sure, my printer will not print beyond the capability of its hot end or other limiting guessed at components. winking smiley
Suggestion: We go vertical fins if we want to stay sans fan. But note that as we print faster we need more heat and with more heat and longer prints we have accumulation of heat in the components and we will require more active style cooling systems. It would not be hard to adapt computer water coolers but, do you print at that rate yet? OR - Maybe you wish to design such a component to be ready for the next wave of evolution in the printers?
As for this thread's hot end? There is deifnitely some more demand and interest to drain out of the new 3D printing market so, there is room for more crowd sourced same type items. Remember how many cereal varieties on the shelf we have at the stores. Many are the same type of flakes in different boxes from different sources yet, not really different. They compete with noise not difference. Here too there is not be any real difference or innovation- yet.
Oh, don't get me wrong ---- Our 3D market does not have enough easily known or accessed parts from reliable sources as this hot end. The market is Brand New and there are many discovering the industry. There are many wanting to enter to build printers and crowd source is a good venue to find parts and help each other. Many manufacturers are emerging and vying for space. So - this item is well timed. It just really isn't engineered or quite - WOW! - and not the next neat item but, its time is NOW! It is attractive. If you time your production to accurate delivery you will be a gem to your supporters. MHO FWIW
grinning smiley
bstott
there is room for more crowd sourced same type items...Here too there is not be any real difference or innovation- yet. ...
bstott
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 06:00PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 06:07PM |
Admin Registered: 15 years ago Posts: 1,470 |
I'm having trouble visualizing how this would work without the set screw shearing the thermistor leads or damaging the thermistor itself. Have you tried this solution in practice? Maybe I'm thinking about it wrong and it works just fine.Quote
RP Iron Man
a set screw secures the thermistor in the heater block and eliminates the possibility of the thermistor falling out.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 06:35PM |
NewPerfection
RP Iron Man
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 06:59PM |
The issue I see is that the set-screw cannot be tightened to stay in place, so would require a thread locking compound to keep it from working loose. Also, I could see many people not reading directions properly and screwing in the set-screw too far and shearing the thermistor leads.Quote
RP Iron Man
If anyone notices a major problem with this design please let me know.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 07:11PM |
NewPerfection
RP Iron Man
A possible solution to consider is using a regular screw (with maybe a low-profile head to look nice) that was the proper length (any M3x3mm screw should work), so that it could be inserted and tightened down without worrying about it loosening or damaging the thermistor.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 08:30PM |
Are you located in the US? If so: [www.mcmaster.com] or [www.ebay.com] ($0.04 each or $0.03 each)Quote
RP Iron Man
Unfortunately, my hardware supplier does not carry M3x3 button head screws. These are actually pretty hard to find so I will probably have to get these from overseas
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 08:48PM |
NewPerfection
RP Iron Man
If you are concerned about looks, another option is to countersink the M3 hole and use a flat head screw: [www.mcmaster.com] or [www.mrmetric.com] ($0.06 each or $0.01 each, plus the cost associated with an extra machining step)
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 09:08PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 11, 2014 10:44PM |
bstott
Screw Thermistor?
Just a quickie --- I've seen screw mount thermistors. Here's a picture. Would you be able to drill a set screw center and pass through the thermistor leads? Then silicone seal the device into the head? Hand tight?
Oh, Eric --- I'm kinda beat today --- I'll respond to your hurt feelings. I know you are putting in effort - we all do. And I like the look. It is a jewel. Later, Brian.
P.S. button head screws ---- boltdepot.com
edit: I forgot. Use the button head of the screw with a washer to capture the thermistor leads against the block and hold the thermistor in the hole. A dab of RTV silicone seal to cover up the Thermistor - Good to over 300°C.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 10:01AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 01:59PM |
uGen
One thing I am rather confused about is that about every all-metal hot end comes with a thermistor as default. This doesn't make much sense to me since the purpose of these hot ends is the higher temperature capability and while E3D also has thermocouples on stock, these are PTFE-coated, again limiting the maximum working temperature to 260°C.
So, what I would absolutely love to see is an option to choose between the default thermistor and a thermocouple. Eric, do you think this might be possible to include in your design?
K-Type Thermocouple on ebay
This one here came to my mind after seeing the screw-in thermistor. Guess that would improve reliability a bit and make everything look rather neat, similar to the one Ultimaker is using:
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 03:19PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 04:24PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 04:40PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 04:49PM |
gmh39
If you do offer the ability to switch between a thermocouple and thermistor, I think you should include both parts with the hotend. Yes, it increases cost, but if your goal is adjustability I think it is necessary.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 05:07PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 05:19PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! [Many Pictures] March 12, 2014 06:01PM |
bstott
Thermistor installation suggestion
[attachment 28496 thermisto.capturer.jpg]
bstott
My little hack was always intended to be active - there was not a passive to it.
Almost all is good.
Hey, you seen anything like this? My hot end nozzle split. Know why? Ha, Ha... The same reason my riser broke.
Some claimed better design ---- The interior diameter was too large with the exterior threads being too deep. This
left the material thickness to hold the part together too thin --- So the parts fell apart. What you are seeing here is
a hot end nozzle which has burst in use. It caused the hot end to leak/ooze and not print properly. This is after I had
a riser failure from the same poor design. That was between the thermistor slipping out, on the same design
AND my PEEK burning UP! LOL....
[attachment 28497 burst-printer-nozzle.2.jpg]
bstott
For cost and use --- better to have option --- One or the other and not supply both.
When you actively build or print you tend to standardize and not goof around with many things. You really have a lot of varying variables and do not just keep swapping stuff. Each thermistor or thermocouple require different electronics and firmware then also settings. So, not practical at the supplier stage either. Just my experience. I have machines with thermocouples and they are good but, I'm not going through the headache to set them up with a thermisor and the electronics. As too with the present machine I've recently built - It has a thermistor and the required electronics. Here, I am not going to build or buy the electronics to convert to a thermocouple and find the firmware adjustments to convert this. Not worth the efforts. As for Thermistors - as noted somewhere in this thread -- they are rated upto+ of 300°C far and above the materials we build the machines with and the materials we print with. If you are going for wire --- You should have a good time with your build. I understand that a few years ago that thermistors may not have been readily available and cheap enough at the temperatures to print so some began to move to a thermocouple. But, as most items, thermistors are now more readily available, the control easier, the electronics less and their functional operating temperatures rising as their costs plummet. So, we use more thermistors now. ???
