Importance of a fan shroud? March 09, 2014 06:01AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Importance of a fan shroud? March 09, 2014 07:29AM |
Re: Importance of a fan shroud? March 09, 2014 08:33AM |
It is nice to see people that use my cooling shield. I will try to improve the shield for you if you want, there are some flaws in the design.
Re: Importance of a fan shroud? March 09, 2014 09:03AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Importance of a fan shroud? March 09, 2014 09:10AM |
nophead
All the heat at the top of a J-head is convected from the heater. If you insulate the heater it barely needs any cooling at all.
Re: Importance of a fan shroud? March 09, 2014 09:41AM |
Re: Importance of a fan shroud? March 10, 2014 02:54PM |
Admin Registered: 17 years ago Posts: 1,472 |
Do you happen to know if the J-Head from reprapworld was made to Brian's specifications? And does the nozzle have the proper 2mm diameter melt zone, or is this a 3mm hot end with just the PTFE liner replaced with one with a smaller hole?Quote
Ohmarinus
It's a Jhead from reprapworld, my 3mm jhead functions perfectly, but this 1.75mm one just doesn't want to work.
If you have the space on your printer's extruder carriage, an E3D hot end is a popular, reliable choice. Or, get a 1.75mm J-Head from Brian himself at hotends.com. They are perpetually out-of-stock, but he posts new ones every Friday at about 12 noon EST, so if you are quick you can get a hold of one.Quote
Ohmarinus
Anyone got advice for a good hotend that prints 1.75mm without any known problems?
Re: Importance of a fan shroud? March 11, 2014 07:17AM |
NewPerfection
Ohmarinus
Ohmarinus
Re: Importance of a fan shroud? March 11, 2014 11:39AM |
In that case I would ask them for a replacement. With proper cooling that hot end should have no problem extruding PLA. Shouldn't need a cooling duct or anything, just some air flow over the PEEK.Quote
Ohmarinus
Yes, the reprapworld J-head is a high-quality hotend with all specifications up to par (so yes, 2mm wide melt-chamber and the PTFE-insert really only sits in the PEEK part). I measured every part and it's correctly produced. The only thing I wasn't able to measure was the nozzle diameter itself (no 0.5mm equivalent in my toolbox).
Re: Importance of a fan shroud? March 11, 2014 12:11PM |
Re: Importance of a fan shroud? April 10, 2014 06:23PM |
umdpru
The fact that the problem occured at exactly the same point in time and location in the print should point the finger at the G-code, in my opinion. that is, unless you have printed other objects with different G-code with success or failure at some other point.
Re: Importance of a fan shroud? April 11, 2014 07:05AM |
Ohmarinus
nophead
Hi, yes I insulated it completely with ceramic insulation band, but still the heat travels up through the inside somehow.
I am pondering buying a new hotend, this thing has given me too many problems! It's a Jhead from reprapworld, my 3mm jhead functions perfectly, but this 1.75mm one just doesn't want to work.
