how to start print at the center April 03, 2014 06:17PM |
Re: how to start print at the center April 04, 2014 10:23AM |
G28 ; to home things M114 ; to see where the printer thinks it is G1 x82 y90 F200; to send it where you think the center is M114 ; to see where the printer thinks it is
PrinterSettings/General/Size&Coordinates/Bed Settings/BedSize: X=164 Y=180 & PrintCenter: X:82 Y90 ; set bed size and center hit the little disk icon to save the settings
Re: how to start print at the center April 04, 2014 01:31PM |
Re: how to start print at the center April 04, 2014 02:12PM |
320000 is several orders of magnitude too high. Most likely you're telling it to try to move say at 120mm per minute (a reasonable but pokey 2 rotations per second with M6 threaded rod) to which the electronics translates to mean it needs to send 640000 steps to the stepper driver. Arduinos top out at around 4000 steps per second and you'd be trying to send 160 times that.Quote
alfadex
In config file is
#define STEPS_PER_M_Z 320000
But if i adjust to half 160000 ,it moves but now the wright distance
Re: how to start print at the center April 06, 2014 07:30PM |
