Sanding down heater cartridge April 13, 2014 04:54PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Sanding down heater cartridge April 13, 2014 04:59PM |
Re: Sanding down heater cartridge April 13, 2014 05:57PM |
Re: Sanding down heater cartridge April 13, 2014 06:19PM |
Ohmarinus
I've seen pictures around of those cartridges and that it might be a good idea to insert them all the way in so that the end side of the cartridge sticks out.
Re: Sanding down heater cartridge April 13, 2014 07:53PM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Sanding down heater cartridge April 14, 2014 07:53AM |
thejollygrimreaper
normally the cases are pretty thick, so you can get away with even giving them a slight touch with a bench grinder
Re: Sanding down heater cartridge April 14, 2014 06:34PM |
Re: Sanding down heater cartridge April 14, 2014 06:50PM |
Re: Sanding down heater cartridge April 14, 2014 07:24PM |
A2
I've used 6 inch long heaters in blind holes, in beryllium copper, and without anti-seize the heater cartridges fuse inside the wells.
I haven't tried it but I have read about using red high temperature automotive silicone inside the well of 3d printer hot ends.
Almost any thing is better at transferring heat than air, just as long it doesn't catch fire, or char.
But if you have a food or medical application, you don't want anti-seize near the finished product.
Re: Sanding down heater cartridge April 14, 2014 08:55PM |
Re: Sanding down heater cartridge April 15, 2014 04:12AM |
A2
Good solution to retain the thermistor, and transfer the heat to the glass bead.
You'll probably have to pick/chisel it out, but it's a good high temp adhesive.
sodium silicate, (water glass) + magnesium silicate, (Talc)+ kaolin (aluminium silicate) + water = muffler sealer.
Sodium silicate
In acidic solutions, the silicate ion reacts with hydrogen ions to form silicic acid, which when heated and roasted forms silica gel, a hard, glassy substance.
[en.wikipedia.org]
Talc
[en.wikipedia.org]
Re: Sanding down heater cartridge April 15, 2014 04:18AM |
Re: Sanding down heater cartridge April 15, 2014 08:05AM |
Re: Sanding down heater cartridge April 15, 2014 08:35AM |
Re: Sanding down heater cartridge April 15, 2014 04:31PM |
Re: Sanding down heater cartridge April 15, 2014 05:07PM |
viduino
I have a Mendel TriC, therefore 3 heater cartridge. The cartridge's core is 4mm x 10mm. I could only find 6mm x 20mm on the market. Where can I find the 4mm x10mm. I am gonna ruin my alum connector if I drill a bigger hole. I bought my printer directly from RepRap and could'nt find the part anywhere ... Can someone provide me with a link?
Thanks a lot.
Re: Sanding down heater cartridge April 20, 2014 12:23PM |
Re: Sanding down heater cartridge April 20, 2014 03:49PM |
