So what happened to cause Reprap to go down? April 18, 2014 11:15PM |
Re: So what happened to cause Reprap to go down? April 18, 2014 11:29PM |
Admin Registered: 11 years ago Posts: 1,063 |
Re: So what happened to cause Reprap to go down? April 19, 2014 01:28AM |
Re: So what happened to cause Reprap to go down? April 19, 2014 03:32AM |
Re: So what happened to cause Reprap to go down? April 19, 2014 04:14AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: So what happened to cause Reprap to go down? April 19, 2014 06:13AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: So what happened to cause Reprap to go down? April 20, 2014 05:11AM |
Ohmarinus
I think there should be a bigger DONATE button on the site
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: So what happened to cause Reprap to go down? April 20, 2014 05:53AM |
Re: So what happened to cause Reprap to go down? April 20, 2014 10:24AM |
Re: So what happened to cause Reprap to go down? April 21, 2014 06:53AM |
vreihen
Nginx was answering HTTP requests but indicated a caching problem after a minute delay trying to load the page.
vreihen
I don't know the exact architecture in use, but from my experience with Apache as a front-end cache to a back-end web server this is almost always a problem with the back-end server crashing or having database problems.
Re: So what happened to cause Reprap to go down? April 21, 2014 11:32AM |
Admin Registered: 13 years ago Posts: 730 |
Re: So what happened to cause Reprap to go down? April 21, 2014 11:39AM |
Re: So what happened to cause Reprap to go down? April 21, 2014 01:27PM |
Re: So what happened to cause Reprap to go down? April 21, 2014 01:40PM |
~/ $ telnet forums.reprap.org 80 Trying 69.46.82.69... Connected to forums.reprap.org. Escape character is '^]'. GET / (html) (head)(title)502 Bad Gateway(/title)(/head) (body bgcolor="white") (center)(h1)502 Bad Gateway(/h1)(/center) (hr)(center)nginx/1.4.1(/center) (/body) (/html) Connection closed by foreign host. ~/ $
Re: So what happened to cause Reprap to go down? April 21, 2014 01:45PM |
Re: So what happened to cause Reprap to go down? April 21, 2014 02:16PM |
Re: So what happened to cause Reprap to go down? April 21, 2014 04:09PM |
Re: So what happened to cause Reprap to go down? April 22, 2014 04:09AM |
Not Found
The requested URL /bin/view/Main/WebHome was not found on this server.
Re: So what happened to cause Reprap to go down? April 22, 2014 03:18PM |
dissidence
The requested URL /bin/view/Main/WebHome was not found on this server."
Re: So what happened to cause Reprap to go down? April 22, 2014 09:19PM |
Re: So what happened to cause Reprap to go down? April 23, 2014 07:10AM |
possible SYN flooding on port 80. Sending cookies. possible SYN flooding on port 80. Sending cookies. TCP: Peer 93.39.64.143:62297/80 unexpectedly shrunk window 779876073:779883373 (repaired) TCP: Peer 187.195.191.16:54635/80 unexpectedly shrunk window 1932683412:1932686316 (repaired) TCP: Peer 187.195.191.16:54635/80 unexpectedly shrunk window 1932683412:1932686316 (repaired) TCP: Peer 212.3.79.6:38850/80 unexpectedly shrunk window 1429369216:1429372694 (repaired) INFO: RCU detected CPU stalls: 1 (detected by 3, t=1007 jiffies) sending NMI to all CPUs: INFO: RCU detected CPU stalls: 3 (detected by 0, t=1002 jiffies) sending NMI to all CPUs: INFO: RCU detected CPU 0 stall (t=1016 jiffies)
Re: So what happened to cause Reprap to go down? April 23, 2014 07:17AM |
Re: So what happened to cause Reprap to go down? April 23, 2014 01:01PM |
Admin Registered: 11 years ago Posts: 954 |
---- "Let me make my move" ---- |
Re: So what happened to cause Reprap to go down? April 23, 2014 06:26PM |
Re: So what happened to cause Reprap to go down? April 23, 2014 07:28PM |
