Arduino 2560 mounting holes
Posted by Dom22
April 19, 2014 11:21PM
M3 socket head will not fit. Nor any spacers or standoffs. Am I missing something?
Re: Arduino 2560 mounting holes
April 20, 2014 02:49AM
Use a snap on PCB nylon standoff.
April 20, 2014 08:57AM
Arduino + Ramps
April 20, 2014 10:05AM
Thanks, that would work. Now I have to find a local supplier.
April 20, 2014 06:53PM
i filled the heads of the bolt down until they fit. but also on the ramps
April 21, 2014 08:57AM
I decided to order some longer screws to go through both boards. I'm just surprised that arduino design does not allow any clearance for screw heads.
April 21, 2014 11:32AM
or for that matter stick to the same .1" pin spacing so that you could use a normal perfboard / protoboard. i always found that choice odd.
Edited 1 time(s). Last edit at 04/21/2014 11:33AM by dissidence.
April 23, 2014 02:34PM
M2.5 fit as well as the equal SAE.
April 23, 2014 11:28PM
Dom22
a lot of the assemblies these days are designed for snap in rather than screw in. I don't know why the Arduino boards are that way but other production boards are that way for ease of assembly and lower cost. It's pretty common.
