Bowden vs Direct Feed Extruder? April 24, 2014 02:19PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 02:33PM |
ayouden
The Replicator 2 is known for its high quality, and the Ultimaker is known for its high print speed.
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 02:42PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 02:49PM |
MrDoctorDIV
This has me rethinking my entire thought of direct vs bowden..
So there is [again, in your humble opinion] no real reason to go direct?
Re: Bowden vs Direct Feed Extruder? April 24, 2014 02:53PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:01PM |
ayouden
ahhhh! I have wondered what these ripples were! it all makes sense now!
Thanks, And I think I will upgrade my current 3D printer to Bowden to see how good it is compared to that of my current direct set up.
Ayouden
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:10PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:11PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:16PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:22PM |
Evil Monkey
If I might jump in here, Sublime I was wondering if you could explain the reason why 3 mm works better than 1.75 mm in a Bowden setup? Less springy perhaps?
Sublime
1.75mm compresses more, most 2mm bowden tubes are thin wall which stretches easier and the fact they use 2mm id tube with flimsy 1.75mm filament means the filament snakes back and forth instead of staying straight against the outer wall, all of which equals hysteresis. For 3mm, 1/8"id x 1/4"od tubing has almost zero stretch and you can not compress 3mm filament much which equates to faster response times and the ability to accelerate the extruder really fast (10,000mm/s^2) during unretracts without the extrusion lagging behind the other axis which can result in missing extrusions at the start of a path. And now with all these new soft materials I think we will find people start to move back to 3mm or even the standard plastic welder 4mm diameter filament.
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:25PM |
MrDoctorDIV
I used to have that on my Solidoodle, then I started playing with settings and nearly elimated those while still maintaining the same print speed [acceleration control was the main difference maker at 1200].
Material variety is a must, so direct drive it stays. Maybe amongst my future upgrades I'll make a quick switchable direct/bowden. Or direct main + bowden support material [or is support material finicky with bowden as well?]
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:34PM |
MrDoctorDIV
Re: Bowden vs Direct Feed Extruder? April 24, 2014 03:37PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 04:59PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:02PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:09PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:21PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:29PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:39PM |
Re: Bowden vs Direct Feed Extruder? April 24, 2014 05:46PM |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 02:39AM |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 09:16AM |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 09:36AM |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 09:59AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 10:01AM |
Re: Bowden vs Direct Feed Extruder? April 25, 2014 10:21AM |
I would agree with thatQuote
konwiddak
On stationary/vertical moving bed machines (ultimaker, delta bot etc) then Bowden makes most sense - they have minimal carriage mass, which you want to keep as low as possible.
For moving bed machines, the bed mass is the likely limiting factor in speed/acceleration, therefore a Bowden doesn't really seem worth the effort.
Re: Bowden vs Direct Feed Extruder? November 16, 2014 12:33AM |
Re: Bowden vs Direct Feed Extruder? November 16, 2014 02:52PM |
Re: Bowden vs Direct Feed Extruder? November 16, 2014 03:16PM |
Re: Bowden vs Direct Feed Extruder? November 16, 2014 10:46PM |
