Bowden questions May 28, 2014 01:14AM |
Re: Bowden questions May 28, 2014 12:00PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Bowden questions May 28, 2014 12:17PM |
Re: Bowden questions May 28, 2014 12:58PM |
Re: Bowden questions May 28, 2014 02:21PM |
Re: Bowden questions May 28, 2014 05:17PM |
ejbantz
Sublime, for the 3mm you recommend... is that the filament diameter... or a retraction length?
Re: Bowden questions May 28, 2014 05:24PM |
cozmicray
You didn't say what printer, or what type of printer?
Filament is not hydraulic --- fluid vs solid.
I would disagree with even 90 deg bends with hydraulics.
The hotend (output nozzle) is always moving!
Sweeping bends in transit tubes in all areas, even supply to extruder.
Shortest route with large radius bends in all positions without twisting.
Run extruder without hotend for smooth, resistance free filament movement.
Extruder directly above the hot end midpoint.
Think of it as transfering the push of the extruder thru the bowden tube
----- with ALL force transfered to hotend tip!
Re: Bowden questions May 28, 2014 05:26PM |
ejbantz
So should the output of the extruder pointing straight up in the air and then arch 180 back down to the x-carriage?
Re: Bowden questions May 28, 2014 05:34PM |
Ralph.Hilton
I'm building a second printer changing quite a few things as it slowly progresses. The new E3D v6 inspired me to to consider going for a Bowden extruder. I was wondering about optimum placement of the extruder motor and what people have had best results from. It would seem best to keep the tube as short as possible so was considering a swivel mount attached to the Z assembly that would go up and down with the X carriage. Does that sound feasible?
Re: Bowden questions May 28, 2014 11:09PM |
Re: Bowden questions May 29, 2014 09:04AM |
Re: Bowden questions May 29, 2014 04:37PM |
