DLP vs FDM July 13, 2014 12:33AM |
Re: DLP vs FDM July 13, 2014 03:41AM |
Re: DLP vs FDM July 13, 2014 11:12AM |
Re: DLP vs FDM July 13, 2014 11:22AM |
Re: DLP vs FDM July 13, 2014 11:30AM |
sanman
I was curious to know if DLP can make parts that have the strength and appearance of polycarbonate. Are there any DLP resins which can do this? What about fiber reinforcement - can DLP make parts containing short fibers for structural reinforcement purposes?
What is the cost of DLP resin in comparison to FFF/FDM filament? Again, I've read conflicting information - some people say DLP resin is cheaper, and others say it's more expensive than filament.
Re: DLP vs FDM July 13, 2014 12:18PM |
Re: DLP vs FDM July 13, 2014 12:24PM |
Re: DLP vs FDM July 13, 2014 12:29PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: DLP vs FDM July 13, 2014 12:41PM |
Re: DLP vs FDM July 13, 2014 12:46PM |
Re: DLP vs FDM July 13, 2014 02:08PM |
Re: DLP vs FDM July 13, 2014 02:15PM |
sanman
nicholas.seward
The metal DLP is probably similar to how we can paste extrude metal clay and then put it in a kiln. Probably most SLA printers will work.
But does this produce a metal part which is as strong as a forged metal part? Or will it be much weaker?
Re: DLP vs FDM July 13, 2014 02:17PM |
sanman
Well, I'd like to be able to print plastic parts which can be directly used in a final product. Or else, I'd like to at least be able to print molds which can be used to make the parts.
So based on what you've said, I guess FFF/FDM is the better choice for me. I value physical robustness of the final part over intricate detail of the geometry.
sanman
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: DLP vs FDM July 15, 2014 09:22AM |
Admin Registered: 11 years ago Posts: 3,096 |
sanman
