Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 12:15PM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 01:36PM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:54PM |
Admin Registered: 13 years ago Posts: 7,004 |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 10:31PM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 10:36PM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,600} // default steps per unit for prusa i3 rework 680 < 850 < 1060 #define DEFAULT_MAX_FEEDRATE {500, 500, 2, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {2000,2000,20,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 02:18AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 02:32AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 02:36AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 04:25AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 02:24PM |
pushthatbolder
what do i set line #480 to?
from
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min)
to
#define HOMING_FEEDRATE {???????????????????????} // set the homing speeds (mm/min)
what do you recommend?
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 28, 2014 09:30PM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 30, 2014 04:13AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 30, 2014 10:45AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) September 05, 2014 11:47PM |
