Arduino Mega drawing too much power
Posted by andybratton
October 13, 2014 07:24PM
Hey all. I've recently run into a problem with my Prusa i2 running on a 2010 MacBook Pro. Whenever I connect my printer to the USB ports on my computer OSX (10.9.4) shuts down the ports because it's apparently drawing a potentially dangerous amount of power. Both ports work with standard USB thumbdrives, etc so it seems like it's not a problem on the computer's end, but I've tried 3 different USB cables and inspected the Arduino USB port for evidence of a short and come up with nothing. Any ideas?
Thanks so much!
Re: Arduino Mega drawing too much power
October 14, 2014 06:48AM
Use a powered USB hub.
October 14, 2014 07:35AM
Did this happen all of a sudden and did the setup work correctly before?
http://www.marinusdebeer.nl/
October 14, 2014 07:36AM
Shouldn't need a powered hub, but the hub will at least let you know if it's a problem with the computer port or Arduino itself without risking further damage to the computer.
October 14, 2014 02:31PM
it is likely the cable is too long and does not provide enough current. what devices are you powering from the atmega?
