Quartz tube test will begin tonight, any test request? November 01, 2014 06:23PM |
Re: Quartz tube test will begin tonight, any test request? November 01, 2014 08:25PM |
Re: Quartz tube test will begin tonight, any test request? November 01, 2014 08:53PM |
Re: Quartz tube test will begin tonight, any test request? November 01, 2014 08:59PM |
Re: Quartz tube test will begin tonight, any test request? November 03, 2014 09:09PM |
Re: Quartz tube test will begin tonight, any test request? November 03, 2014 09:59PM |
Re: Quartz tube test will begin tonight, any test request? November 03, 2014 10:40PM |
Re: Quartz tube test will begin tonight, any test request? November 03, 2014 10:45PM |
Re: Quartz tube test will begin tonight, any test request? November 03, 2014 10:55PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 05:33AM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 07:01AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 11:05AM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 05:53PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 05:55PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 06:02PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 06:17PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 08:49PM |
Re: Quartz tube test will begin tonight, any test request? November 04, 2014 11:58PM |
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 01:29AM |
Zerker
One thing I would note against the non threaded tube is that once you glue it in it's almost permanent.
If the glue can be dissolved with a solvent then great, however if it cant and you break the glass, your gonna need a new hotend.
an RP printed "Clamp" could be made that slips over the end of the metal cold end and the back of the glass tube to hold it in place with tension in the RP part instead of an adhesive?
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 06:23AM |
tmorris9
Zerker
That is the same thing I was thinking. A mechanical fit so when the nozzle is screwed in place is squeezes tight against the end of the tube but inside a metal tube to protect the glass.
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 10:50AM |
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 12:50PM |
ggherbaz
I will post a new design I have in mind, I learned from my mistake, I'm planning on use cone shape ends, and a main body set in 3 pieces, brass heater block, middle quartz tube and aluminum top hold together with 3 spacers and bolts to prevent over tight and twisting. The nozzle will press against the heater block instead of the quartz tube.
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 01:04PM |
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 04:04PM |
Re: Quartz tube test will begin tonight, any test request? November 05, 2014 04:48PM |
Re: Quartz tube test will begin tonight, any test request? November 06, 2014 09:56AM |
Re: Quartz tube test will begin tonight, any test request? November 06, 2014 05:37PM |
Re: Quartz tube test will begin tonight, any test request? November 06, 2014 05:51PM |
Re: Quartz tube test will begin tonight, any test request? November 06, 2014 10:31PM |
Re: Quartz tube test will begin tonight, any test request? November 06, 2014 10:37PM |
