Colour mixing now a reality November 03, 2014 01:34PM |
Re: Colour mixing now a reality November 03, 2014 01:47PM |
Re: Colour mixing now a reality November 04, 2014 04:55AM |
Re: Colour mixing now a reality November 04, 2014 08:43AM |
Re: Colour mixing now a reality November 04, 2014 09:45AM |
Re: Colour mixing now a reality November 04, 2014 10:17AM |
Re: Colour mixing now a reality November 04, 2014 10:30AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Colour mixing now a reality November 04, 2014 11:03AM |
Re: Colour mixing now a reality November 04, 2014 11:17AM |
Re: Colour mixing now a reality November 04, 2014 11:23AM |
Can you direct me to a picture where you see the material.Quote
UkIan
Question for you: What is the clay like material you put around the hot bits? I've been looking for something like that and haven't found anything that likes hot temperatuers.
Re: Colour mixing now a reality November 04, 2014 11:41AM |
ekaggrat
do the filaments mix properly or do you get a toothpaste effect like richard's 3 way extruder ?
Re: Colour mixing now a reality November 04, 2014 01:18PM |
Xabbax
UkIan
Re: Colour mixing now a reality November 04, 2014 05:19PM |
Re: Colour mixing now a reality November 04, 2014 05:35PM |
Paul Wanamaker
Ulkan,
I've used Autocrete- Hi-Temp Ceramic Adhesive when building my hot-end.
It worked very well.
I really like the tri-color hot-end. Great Job!
I am planning one for Raptosaur, and water cooling may work best.
Re: Colour mixing now a reality November 04, 2014 06:08PM |
Re: Colour mixing now a reality November 06, 2014 01:03PM |
Re: Colour mixing now a reality November 11, 2014 10:40AM |
Re: Colour mixing now a reality November 12, 2014 03:29AM |
Re: Colour mixing now a reality November 12, 2014 04:00AM |
kimented_
Your work is great and promising!
I see you only change the color by the Z axis. It is not possible to change the color on X-Y ? Are you already working at this stuff?
Re: Colour mixing now a reality November 12, 2014 04:22AM |
Re: Colour mixing now a reality November 12, 2014 05:00AM |
Re: Colour mixing now a reality November 12, 2014 07:10AM |
Yes you can build your own colour scheme. I used the basic red, yellow and blue(Not RGQuote
Ohmarinus
So, if you manage to mix two colors, do you get a new color if you are using three primary colors as base filament? That way it theoretically *should* be possible to output RGB values.
Re: Colour mixing now a reality November 12, 2014 07:28AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Colour mixing now a reality November 12, 2014 07:35AM |
dave3d
Printing with 3 primary colours, an RGB printer in effect, would in theory allow sophisticated multi coloured art work or lettering to be incorporated within the print if the software was capable of it. This would be a game changer.
Xabbax, after your earlier post I started to source the bits to make a hotend myself. I have not got very far yet. It is a fairly complicated assembly that needs to be silver soldered together. Any plans to sell them? or as garyhlucas suggested getting a version metal printed that you can mass produce and put on the market?
Does having 5 tubes going into the hotend present any particular problems? Did you need to beef up the motors or slow the print down?
Re: Colour mixing now a reality November 12, 2014 08:03AM |
nophead
You need the secondary colours, i.e. cyan, magenta and yellow when mixing pigments that absorb and reflect light as they are subtractive. The primary colours are used for processes where the colours add.
Re: Colour mixing now a reality November 12, 2014 08:28AM |
Re: Colour mixing now a reality November 12, 2014 09:32AM |
nophead
Re: Colour mixing now a reality November 12, 2014 09:37AM |
My apologies for the confusion!!Quote
nophead
I think you confuse me with RichRap. I have never done any colour mixing since mixing paints at school!
Re: Colour mixing now a reality November 12, 2014 10:04AM |
cat.farmer
nophead
you would also need black and white filaments for color mixing to create the proper shade.
Re: Colour mixing now a reality November 17, 2014 06:24AM |
