ebay J Head hot end November 18, 2014 04:38PM |
Re: ebay J Head hot end November 18, 2014 04:50PM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: ebay J Head hot end November 18, 2014 05:07PM |
While definitely not being a real jhead, no where does it say that it's a E3D hotend. It's a hot end, and it's similar, but it doesn't claim to be what it's not so I don't think you can call it a counterfeit. Maybe a knock off...and a cheap one at that. Caveat emptor...you get what you pay for...etc...Quote
thejollygrimreaper
what you have there is actually a counterfeit E3D hotend sold as a Jhead
Re: ebay J Head hot end November 18, 2014 05:18PM |
cdru
thejollygrimreaper
With a real E3D hotend you should be able to screw the nozzle into the heater block so that there is a slight gap between the nozzle and the bottom of the block, then screw in the heat break until it makes contact with the nozzle. Then screw the heat sink onto the break. If it spins all the way down without tightening, then it was either threaded too far or the break is two short. But there definitely should be a break there. Having the heater block contact the heat sink defeats the whole purpose of having the narrow break.
Re: ebay J Head hot end November 18, 2014 05:22PM |
Re: ebay J Head hot end November 18, 2014 05:52PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: ebay J Head hot end November 18, 2014 06:03PM |
Re: ebay J Head hot end November 18, 2014 06:10PM |
DisruptiveTech
It's a poor artist that blames his paint brush.
Re: ebay J Head hot end November 18, 2014 06:45PM |
zerodamaeon
That saying does not really apply here unless you mean it in the sense that a artist buys a brush without any bristles and paints a horrible picture then tries to blame it on the brush.
Re: ebay J Head hot end November 19, 2014 12:17AM |
Re: ebay J Head hot end November 19, 2014 07:13AM |
Re: ebay J Head hot end November 19, 2014 07:45AM |
jmorken
I thought it was a standard size part so would just work
This is the mechanical endstop I used:
[www.ebay.com]
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: ebay J Head hot end November 19, 2014 09:43AM |
Re: ebay J Head hot end November 19, 2014 09:55AM |
Re: ebay J Head hot end November 19, 2014 10:13AM |
Andrew Smith
Teflon lining and an advertised limit of 300C?
With no PEEK or PTFE in hot regions of our HotEnd we can reach 300C with the supplied thermistor. By swapping a thermistor for a thermocouple (may require additional electronics) you can reach over 400C.
Re: ebay J Head hot end November 19, 2014 10:14AM |
