Which controller should i use? December 01, 2014 01:53PM |
Re: Which controller should i use? December 01, 2014 03:18PM |
Re: Which controller should i use? December 01, 2014 03:23PM |
Re: Which controller should i use? December 01, 2014 03:36PM |
if i put them in parallel or in series do you think i will overload the driver? also does the program (eg. pronterface) make adjustments if the 2 steppers are on different driver?Quote
gforce1
Radds will do, it fits 6 steppers. You only need 6, Z1 and Z2 go on 1stepper ( parallel or series).
Re: Which controller should i use? December 01, 2014 04:15PM |
Series increases low speed torque over parallel, but loses torque at high speeds. Parallel has lower torque overall, but can maintain it at higher speeds.Quote
luckcolors
if i put them in parallel or in series do you think i will overload the driver?Quote
gforce1
It depends on your firmware capabilities. Marlin for instance allows RAMPS users to use the 2nd extruder driver to drive a 2nd z-axis. I'm not sure specifically for RADDS or Duet how/if that works the same way. Edited to add: Since you mention pronterface, no, pronterface doesn't do that. It happens at a lower level, in the firmware such as Marlin. Your host software would just tell the microcontroller to position your hot end at # position and the microcontroller would handle the details of how to do that.Quote
also does the program make adjustments if the 2 steppers are on different driver?
Re: Which controller should i use? December 01, 2014 04:38PM |
Re: Which controller should i use? December 02, 2014 08:55AM |
Re: Which controller should i use? December 02, 2014 09:39AM |
I'd say RADDS > RUMBA > RAMPS if you really need 6+ stepper drivers. RADDS is 32-bit and would be faster and more future-ready. RUMBA is based on RAMPS and runs on the same microcontroller (ATMEGA 2560), is more integrated (single board), has the built in 6th driver, and supports 1/32 microstepping.Quote
luckcolors
Anyway which board is better betwen : RADDS, RAMPS or RUMBA ?
Re: Which controller should i use? December 03, 2014 08:45AM |
Re: Which controller should i use? February 14, 2016 07:39AM |
