Can someone post up the G-Code for a simple object for the current (five-d?) firmware. I want to try sending a few other commands along with it, but I can't get the software to save to a file. Nevermind, I am just sending codes manually.
Or is there a way to manually send G-Codes?Nevermind, figured out how to do this. I'm using a program called GTKTerm.
Also, for the Extruder PWM (M113) What is the range for the S value? The example is 0.7 so is it 0-1 or is it the actual value that it would otherwise read from the pot 0-1023?
Edited 1 time(s). Last edit at 04/28/2010 04:28PM by Azdle.
Build Progress Blog
